1969 cutlass convert rear armrest light harness
Old Nov 18, 2021 | 02:15 PM
ej69's Avatar
While removing rear set, noticed rear armrest courtesy light wiring has been repaired by past owner and doesn't look good. Light sometimes works and others doesn't. Appears orange and white wires from each courtesty light is factory sliced in to harness running along trans tunnel. Orange wire at splice has broken and there are butt connectors near each bulb assembly. Is there a replacement harness for this section or does it go all the way to the front or would it be easier to repair the issues. I tried to research on line and haven't been able to find a harness for this
thanks eric
Old Nov 18, 2021 | 02:29 PM
Don't over think this, just replace the wires and use solder and heat shrink instead of the butt spices. The wires will be hidden and the light does not care what color they are. The orange wire is hot at all times and the white is the switched ground side operated by the door pin switches and the headlight rotary switch.
Old Nov 18, 2021 | 03:35 PM
ej69's Avatar
figured that was going to be the solution. was hoping there would be a replacement harness w/ new wires and bulb connector.
thanks
Old Nov 18, 2021 | 04:26 PM
Texas69's Avatar
American Autowire has replacement harnesses that are plug and play, but are very expensive.
Drake Simon
Oct 24, 2021 04:27 PM
69_olds
Jul 10, 2015 06:12 PM
Gary's 2 442-S
Feb 8, 2014 09:45 PM
GoodOldsGuyDougie
Jun 18, 2011 12:27 PM
bittersweet71
Mar 16, 2011 10:29 AM
