Brown/white charge warning lamp resistor wire?
Old Oct 30, 2020 | 07:59 AM
As the title says, what’s the original purpose of the brown/white resistance wire that goes from the brown wire (accessory power feed) of the ignition switch, to the brown wire (alternator warning lamp wire to the regulator) at the firewall connector?
I asked this because a friend called asking about a charging system conversion on a 68 Lemans. The only thing I can think of for why it’s there is so the charge lamp glows dim in the accessory position. Was it intended as a reminder that the key is in the accessory position?
Old Nov 2, 2020 | 06:37 AM
Nobody has a clue?
Old Nov 2, 2020 | 06:38 AM
It acts as excitation in case the lamp burns out causing the alternator to charge.
Old Nov 2, 2020 | 07:32 AM
it acts as excitation in case the lamp burns out causing the alternator to charge.
^^^this!
Old Nov 2, 2020 | 10:18 AM
That makes sense. Always wondered, now I know.
F85 330 ctls
May 29, 2019 10:31 AM
70 ctls
Nov 19, 2018 04:36 AM
Demond's Muscle Car
Nov 30, 2014 05:17 PM
rroth01
Jun 18, 2011 10:22 AM
jag1886
Jan 12, 2011 07:37 AM
