Headlight Relay Installation Directions
Decided to install headlight relay switches as the first step in my headlight upgrade. Did a few searches and came up with partial help..... can anyone please direct me to video or process (with pictures)? Particularly would like to make sure I pick the correct low beam and high beam wires in the wiring harness. Low = red/black and high = lt green/black?
I'll just add that if the OP is planning to upgrade the lights to something with a higher current draw (like HID lights). you'll need to upgrade the wire gauge from the relay to the headlights also.
sorry for omitting car info..... 1970 Cutlass S. 350 Rocket. TH350 trans. Thanks for the info above!!! The overall endstate is either a set of the Brites, T3s, or Halogens. I'll upgrade the wire from relay to headlights! Thanks
Last edited by sschevellecutlass_Bob; January 8th, 2018 at 10:16 AM. Reason: adding pic
As for color codes, just look at the back of he headlights. Green powers the high beam filaments and tan powers the low beam filaments.
ok ... picked up halogen headlights and relay parts........Stumped on where I splice the second relay????? It seems obvious that the first set of wires is in the front lamp harness running across the driver's side inner fender..(arrow in pic) ....but where is the second set? Do I splice the relay into the wires near the headlight? Thanks!
As stated in the post with the drawing the lamps are in parallel, 1 relay for hi beams and one for low. I would try installing the lamps without the relays first.
Here is a better diagram
Your going to cut the 2 light wires, one side will connect to terminal 85, the other to 87 for respective hi or low beam relay and wire.
I get it now!!! I drew it out on the wall board at work. Thanks for the patience and the second diagram. I'll try the healights first, but I do notice that when at idle the headlights dim a little then get brighter when I press on accelerator. Thought that meant a relay was necessary. ?
Installed the halogens today - super nice difference. based on above expert guidance, I tested the battery voltage at rest, and under load and since it was a constant 13, I just plugged in the headlights without installing the relay. steady 13 with the halogens too. So, i'll hold off on installing the relays at least for now. Halogens really make a great difference in visibility and confidence now. THANKS again all!
Guys,
I have been following this since I have been thinking about the relays too. My alternator is only putting about 13.5V. I measure 12.5V at the headlights.
Should my '67 442 alternator be putting out 14.5'ish. If so, then may I should start there. If I should expect 13V at the headlights, then maybe the relays not worth 0.5V.
-Jeff
-Jeff
Guys,
-Jeff
-Jeff
A lot of the automotive lamps are actually rated at 12.8VDC nominal. If you are getting 12.5VDC at the socket terminals, the relays really won’t do much unless you get a ton of voltage drop under load.
Why do you think you need to take load off of a switch with contacts that were designed to carry that much current? Again, if you are replacing the stock lights with ones that draw a LOT more current, yes you need both relays and upgraded wiring. Otherwise, you are just adding complexity, cost, and potential failure modes.
I don't disagree Joe, only answered the question. My suggestion to the OP was to try his halogens first without the relays. People install relays and fuses everywhere for both perceived good and bad reasons. I use a Ford starter solenoid for my mini starter and a 30A relay to supply my HEI. I'm not one to judge.
The idea is to allow the headlights to get power directly from battery and not passing it through 50+ year old headlight & ignition switch contacts that have worn and corroded.
I believe the halogens are typically higher (rated) wattage/current than the old incandescent lamps were as well. Could be wrong.
Another thing to think about is that lamp output vs voltage/current is not linear. Much more dramatic losses right off the rated voltage than further down the curve.
I’d be more inclined to add the relays if you’re seeing lower voltage at the lamp contacts and further dimming under engine load. My 72 W30 has dim halogens that get worse under engine load. I’ll be adding the relays whenever I get time.
For sure it can’t hurt removing the current from the 50+ year old headlight switch. Have seen night and day differences (pun intended) in lamp performance with the relays added.
RobFayette
May 20th, 2015 07:58 AM
RobFayette
May 17th, 2015 05:03 PM
Creativeindy
Drivetrain/Differentials
September 4th, 2012 06:39 AM
