67 Cutlass fuel gauge inop
Old October 31st, 2017, 08:40 AM
Roger60's Avatar
Fuel gauge not working. New sender, power to sender, good ground, power at dash upper left terminal, ground at right upper terminal and lower terminal with gauge out. With gauge installed, test light does not light at all. Manually move the needle, turn on ignition, and it moves back to empty. I know I have 8-10 gallons of fuel in tank. Whatcha think? Thanks
Roger60 is offline
Old October 31st, 2017, 09:06 AM
If you remove the sender wire with the key on, does it go to full? If you ground the wire does it go to empty? If yes to both, then your float is not adjusted correctly. The gauge does not move linear as the tank empties due to the dimensions of the tank. So 1/4, 1/2, 3/4, and full is not necessarily accurate.
oldcutlass is offline
Old October 31st, 2017, 10:00 AM
Roger60's Avatar
Thanks, that is exactly what it does. Any tips on adjusting the float?
Roger60 is offline
Old October 31st, 2017, 10:48 AM
You have to drop the tank and shape it like the old one. Fill the tank and see how far up the needle goes. On mine if I fill it to the neck and see fuel then the needle reads past full. If you want to change it you have to drop the tank and bend the arm. Using the old one as a guide helps a bit if it was somewhat accurate.
Old October 31st, 2017, 10:57 AM
Roger60's Avatar
Do I still have to drop the tank if I have clear access to the sender from underneath, such as on a lift?
Roger60 is offline
Old October 31st, 2017, 10:59 AM
Were you able to pull out the sender with the tank mounted when you changed it?
Old October 31st, 2017, 11:37 AM
Roger60's Avatar
Yeah, new tank went in first, then the sender.
Roger60 is offline
Old October 31st, 2017, 11:48 AM
Roger60's Avatar
Roger60 is offline
Old October 31st, 2017, 01:17 PM
Precisely full is not absolutely necessary, reading over full at full is ok to a certain extent.
Empty, on the other hand, has an entirely other connotation. Cars seem to either have a little past empty, or empty means empty. I think these cars had full meaning full, and empty meant you were out.
Koda is offline
Old October 31st, 2017, 01:52 PM
From your picture, no need to drop the tank. You'll have to play with it.
JPMDaddy
January 31st, 2020 04:01 AM
lemoldsnut
May 26th, 2014 02:35 PM
lemoldsnut
August 20th, 2013 09:32 PM
Koby
October 1st, 2011 02:30 AM
Z3d
November 18th, 2009 10:47 AM
Quick Reply: 67 Cutlass fuel gauge inop
