Coil Resistor
Old Apr 1, 2009 | 12:19 PM
Wasted's Avatar
Coil Resistor
I feel pretty dumb asking this but, Where is the coil resistor located on a 70 Cutlass Supreme with a 455? I have looked everywhere for it and can't find it.
Old Apr 1, 2009 | 01:01 PM
Lady72nRob71's Avatar
Didnt these years use resistor wire instead?
I am pretty sure my '72 does. A bypass wire is switched in during cranking to give more power to the coil then.
Old Apr 1, 2009 | 01:17 PM
wmachine's Avatar
Trying to remember member
I presume it is in '71, as I know it is in the mid '60s. On my first '66 442, the wiring had been cut back too far, and the "resistor" was cut out. Was quickly burning the crap out of points, and I couldn't figure out why! Finally guessed that may be it, and bought a common ballast resistor, mounted it on the firewall, and no more problems!
Old Apr 1, 2009 | 02:59 PM
As noted, the "resistor" is simply built into the wire. The harness uses a resistance wire, not a separate resistor.
Old Apr 1, 2009 | 03:29 PM
jensenracing77's Avatar
if the wire is original it is a resistor wire. start the car and check the volts at the + side of the coil. if you have around 6 volts you should be good. if you have 12 to 13.8 volts you do not have a resistor or resistor wire.
Old Apr 1, 2009 | 03:48 PM
Wasted's Avatar
I have one volt. So Im guessing that I have to replace the resistor. Or dose having 1 volt mean something else?
Old Apr 1, 2009 | 07:18 PM
Having 1V means that the resistor wire is resisting too much. Do the turn signals or backup lights work? If so, then you will need to follow that wire back to the firewall connector. If you get 12V there, then the resistor wire needs to be replaced. The whole resistor wire runs from the firewall connector to the coil.
Mak
May 28, 2013 04:46 PM
wolskara
Sep 10, 2010 08:06 AM
NikkiLee
Mar 22, 2009 04:27 PM
dan2286
Feb 5, 2009 06:42 PM
david adelberg
Jun 2, 2008 06:10 PM
