Wonky cruise control
Old Nov 14, 2006 | 06:42 AM
bandit600's Avatar
Having trouble with my cruise control. Once engaged, the slightest change in speed causes the c.c. to speed the car up slightly to return to the set cruise speed, but it always overshoots so the c.c. let's off the throtle a bit, then undershoots the speed, so tries to speed up again.... it just keeps yo-yoing up and down a couple miles an hour; it never seems to be able to adjust the throtle properly to get itself at, and keep, the set speed. It's like a bad taxi driver (no offense to an taxi drivers out there, they're notorious for that here in Montreal.)
I don't know if it's the vacuum actuator or the or the c.c. transducer?
Help.
Old Nov 15, 2006 | 09:10 PM
Redog's Avatar
CC is vacuum controled on carb'ed cars but I don't know where the port is
Old Nov 17, 2006 | 07:41 AM
bandit600's Avatar
Tried lubing all the throttle mechanism and speedo cables last night. Speedo needle isn't smooth, jumps a bit.
No change.
Can't locate any adjustment on the transducer.
Old Nov 17, 2006 | 05:26 PM
ozoneblue's Avatar
Thumbs up Cruise control
Now that you said speedo jumps ,There is the problem you must have the old style unit ...Disconnect cabels from unit & lube them , Then on cable side there are 2 1/4 " screws remove them seperate housing , Mark your place. blow out dust from clutch side .Cable end ,spray with lube re assemble & test drive this has always worked good on the old style units . If yours is not this unit ,this Info is useless to you
Old Nov 18, 2006 | 02:10 PM
Redog's Avatar
it's a jummping speedo needle mean you need a new cable from speedo to tranny?
Old Nov 18, 2006 | 04:49 PM
ozoneblue's Avatar
Do you have the old style? If so the cables are connected to it ,You never told us Make Model & Year,so I am guessing
Old Nov 20, 2006 | 05:59 AM
bandit600's Avatar
It's a 1977 Delta 88 Royale
Old Jul 6, 2008 | 05:53 PM
Hi Shane,
I had almost exactly the same problem with my 1983 Ninety Eight. From 77-83 I don't know how much change there was, but I'll bet it wasn't much because my system ran on vacuum too. Here's what I found: Check all your vacuum lines for signs of a leak. If you've got hardened old lines connecting the carb and transducer, they may look good but are not holding vacuum which can cause surging. Strangely enough, also make sure your carb is bolted down good and tight to the manifold so it doesn't have vacuum issues. The other thing to look for is a replacement transducer. (You're in Montreal? Check around salvage yards - also check Toronto greater Met area re-cyclers. Just based on age, it's possible the transducer is shot.
Allan R
mruders
Feb 4, 2014 08:15 AM
Col Wickham
May 24, 2010 11:10 PM
ncwitte
Ninety-Eight
Apr 12, 2007 05:03 AM
Mr. King
Mar 28, 2007 06:26 AM
ztim
Dec 22, 2006 10:17 PM
