Wire ID
Wire ID
Can anyone help me identify these two wires?
I tried the Serv Manual schematics but wow it is tough to decipher.
One wire is brown (I think) and covered in a stainless steel shielding or sleeve in addition to the coloured wire insulation itself. It travels along the firewall and enters the car between the brake booster and fender. Inside it seems to pass by the guages and terminate somewhere (by feel) behind the heater controls or that area anyway.
Could it be the rear defogger power wire?? Or is this a wire for the coil as it seems to have suficient length to reach it??
See Pic #1
In Pic #2 I have located two wires that are attached to one terminal and I think they go to the coil but I am not sure. Is one the ignition wire and the other the tach wire??
Do these go to the POS terminal of the coil??
See Pic #1
the shielded wire looks to be the original tach wire. the one with the two looks like the original ignition wire to the coil. it looks like you have an MSD distributor? if so did you install it? if not and the car runs someone ran a new ignition wire to feed it 12 volts as the original is a resistor wire.
Any chance it could be that?
The tach wire would be separate.
And, yes, they do go to the + terminal of the coil.
Thx guys!
The car hasnt run yet since I installed the motor. I installed the MSD and I am just trying to make sure all the connections are correct.
Eric - As for antenna wire, I'm not sure. Its a small wire - not typically what I'm used to like in my Grand Nat'l. It is shielded tho, but where is the antenna? I dont have one mounted on the car anywhere....at this point I'm praying its the tach wire!!
The antenna wire is thick, like you'd expect.
If original, it would be expected to go through the firewall in the center, just under the windshield (has two small screws that hold a bracket to the firewall, if I recall), from the inside side. The antenna is in the windshield.
Sounds like it's the tach wire. Having never had an OEM tach, I had not known that the original wire is shielded.
what MSD are you using? if it is something like a 6A or other that has a separate box with a dedicated tach connection then I think you need a tach adapter from MSD. the MSD uses a different signal than the original GM tach's that ran from the coil. you could probably hook it to the coil and it should work but you may want to check with tech service at MSD.
Its an MSD Pro-Billet PN 8529. (Olds model)
Just a distributor - not a 6a box etc. Has a simple hook up to the pos and neg terminals of the coil plus a gnd. The MSD has a gry tach wire coming from it. I'm hoping it works okay. If not I'll hook it to the coil.
If it goes to the coil then to which terminal?
68cutlassdriver
March 6th, 2011 11:53 AM
