Wire boot for sending unit
Old Jul 7, 2020 | 04:22 PM
NorthBay72supreme's Avatar
I replaced the sending unit on my 72 Cutlass. When removing the old one, the rubber wire boot for the sender wire was destroyed.....or at least the metal inside the boot was.
I can't seem to find it anywhere. Ordered the new part from original parts group. They didn't provide a new boot and don't sell them. Had no luck locally through Oreilly, Napa, etc. Tried Grainger and struck out there as well.
SOS. I need help and quick. My wife is going to drvie me crazy if she complains about the gas tank on the floor of the garage one more time
Old Jul 7, 2020 | 04:29 PM
I'm not sure you might find solely the boot but I know ILT sells a complete wire assembly including the boot. Is this what you are seeking?
https://www.inlinetube.com/products/inl10613
Old Jul 7, 2020 | 05:56 PM
From what I recall, that is just a straight push-on connector like a bullet connector. You should be able to get one at the local hardware store. Get the old one out of the rubber, cut it off, crimp the new one onto the end of the wire, then stuff it back into the rubber.
f
Old Jul 7, 2020 | 07:40 PM
BackInTheGame's Avatar
It is a 90' push-on connector. A straight push-on would be too tall to fit between the tank and the underside of the trunk floor. I bought the Inline Tube version that Norm posted. It is a well-made piece. The rubber boot is soft and pliable, and seals well around the sending unit's connector. You might be able to make a straight connector work if you bent it, but you will not get a good seal when installed.
Old Jul 8, 2020 | 11:27 AM
That's the one! Thanks a MIL!
Old Jul 8, 2020 | 11:46 AM
Seems as it would be simple enough to solder the wire onto the straight connector so it's at 90 degrees. Oh well, I'm a DIY kinda guy but others may not be as "creative" in their solutions to problems as I am.
cbartonbrown
Jun 5, 2018 11:37 AM
Rosco920
Apr 21, 2018 07:55 PM
Mike70GoldOlds
Jul 8, 2017 07:57 AM
willj
Feb 4, 2010 01:45 PM
Flye
Sep 27, 2009 12:42 PM
