What's this plug???
Old Jan 1, 2016 | 08:33 PM
1983oldsmobiledelta's Avatar
What's this plug???
What is this plug to I found it when getting ready to pull my engine its been melted it was on the left side of the car its a 83 delta 88 engine 307
Its the plug on the left
Old Jan 2, 2016 | 06:46 AM
That's one of the plugs for the solenoid valves on the air diverter valves mounted behind the A.I.R. pump. There should be two total in that general area. Part of the CCC emissions controls.
Old Jan 3, 2016 | 03:23 PM
That wasn't it its still plugged up but it does look just like it also found this plug any ideas what it is
Old Jan 3, 2016 | 03:33 PM
The green connector is the test connector for the mixture control solenoid in the carb. It is not normally connected to anything. You attach a dwell meter there to read the mixture control duty cycle when adjusting the carb.
The two-wire connectors like the one in the first photo are used for the A.I.R. diverter valves (two of them) as well as for the anti-diesel solenoid on the driver's side valve cover. I only see one of the A.I.R. valves in the photos. The other was bolted to the back of the missing air pump.
Old Jan 3, 2016 | 03:49 PM
So your saying I'm missing a air pump or that was just run for diesel engines and I don't need it I'm sorry just a little confused
Old Jan 4, 2016 | 07:01 AM
Yes. Something had to pump air into the tubes that go into the exhaust ports. The pump mounts to brackets (also missing) above the fuel pump and directly below the (missing) A/C compressor.
Old Jan 5, 2016 | 09:46 PM
I'm sorry I just thought about it I had to remove the smog pump and check valve that the plug goes too thanks for the help car been siting for 2 years due spun bearing just slipped my mind thanks for pointing that out
ds00469
Jan 25, 2014 05:12 PM
prawnman88
Apr 27, 2007 07:54 PM
66starfire
Jan 3, 2007 10:31 AM
ztim
Dec 22, 2006 10:20 PM
<james.reinhart@detroitdie>
Jul 24, 2004 09:34 PM
