What are these used for?
See the attached pic. I have a 1972 olds cutlass 350 2 barrel and want to know what these two boxes are exactly used for?
I will be upgrading to a 4 barrel intake and Holley vac sec carb and want to cleanup and remove all extra wiring and vacuum lines, as well as upgrade my ignition to an MSD vac dist, 7AL3 (have one laying around) red box, MSD coil etc...
Left, voltage regulator to your alternator. IN 1972, alternators were not regulated internally. They had an external very mechanical regultaor.
On the right, that is your junction as well as horn relay, when you beep, you should hear a click of some sorts.
Why are you upgrading your ignition, is there something wrong with your current one?
boxes
Can you guys elaborate more. The horn relay is a horn relay so that will stay, but I see about a 1/2 dozen other wires hanging off of it. Also, I'll consider running an aftermarket alternator to remove the voltage regulator? I hate clutter
My plans are to run an MSD 7AL-3 Ignition system that came from my superstocker so I can eventually use my 3 step, PG w/transbrake.
I just don't remove something from either of these 2 boxes that will affect my lights or key ignition. Also, I'm just trying to clean up the engine compartment if I can.
Tony, the car in my sig will be a predominant bracket car next spring that will see some rides to the ice cream shop (but not too many). Not much for cruising, plus I have a ton of race parts laying around that I have spent thousands on over the years that I would like to use.
http://www.summitracing.com/parts/SUM-1667
x2 on the wiring diagram, must have for an old car. It's also in the Chassis manual if you get a hard copy. Horn relay serves as a hub for much of the electrical in the car so not easy to eliminate. Condenser on the VR not needed if you get a modern solid state one which also fixed flickering lights in my car.
Kaline
Mar 22, 2008 08:31 PM
Want-A-Vert
Brakes/Hydraulic Systems
Jul 16, 2007 07:50 PM
