voltage regulator/Delco Remy
Old Sep 17, 2006 | 05:47 AM
and1stp's Avatar
Polarizing my generator. I need to place a jumper wire between the GEN and BAT leads on the voltage regulator. I have no markings on the regulator. Looking at the regulator I have 3 leads(post). The first one (Red) goes to battery. Second lead (middle post) looks like same wire that goes to the generator (wire goes into wire harness). Third post not sure where this goes.
To make sure, Is post 1 the BAT and the 2nd post GEN?
Never owned a car with a generator, and discovered this proccess by chance.
Thanks,
And1stp
'55 Olds 88
Old Sep 17, 2006 | 01:30 PM
ozoneblue's Avatar
Voltage regulator
IMost marked on back side If no its Batt Gen Field field being the light blue
Old Sep 17, 2006 | 07:31 PM
and1stp's Avatar
Thanks for the reply Ozone,
Do you mean its marked inside the cover? The wires from left to right as the regulator sits on the inner fender well are Red, light purple and black(being the smaller guage wire of the other two).
ros6872
Oct 29, 2014 10:57 AM
ros6872
Aug 13, 2014 09:45 AM
delta_88_germany
Feb 22, 2014 01:48 PM
war eagle
Apr 19, 2010 08:13 AM
66-3X2 442
Sep 29, 2009 03:09 AM
