voltage regulator
voltage regulator
i have a 69'olds88 delta and need to replace the voltage regulator.
now it seems that they are with internal and external voltage regulator.
I read in my workschop manual that i have a generator.
with do i need?
i thought with the internal voltage regulator, am i wrong?
with do i need?
with do i need?
with do i need?
Despite what the manual says, you do not have a generator. For some reason, GM referred to the Delcotron alternator as a generator, but it is not.
Assuming you have an exteranal regulator, it will be a black cube on the firewall, about 3" by 3" with four wires going into it. You can get exact replacement mechanical regulators or you can get newer electronic regulators that are direct replacements.
If you are trying to describe polarizing the generator, that is NOT required on this car. DO NOT do it. The car is a 1969 model. It does not have a generator.
So if i order a new delco voltage regulator 3x3inch box.
i need the one with external regulator.
it has 4 wires 2 going to the alternator on the firewal.
it's the original one.
cleaned it but don't trust it. it ratels and the rpm drops.
so i looked at fusik's place for a replacment and saw 3 different ones.
so i need the d663 one? and not the d680.
delta_88_germany
February 22nd, 2014 01:48 PM
