Vintage air
Old Jun 22, 2018 | 06:11 PM
kbdecatur's Avatar
Vintage air
I have a squeal on my a/c belt that I can’t get rid of. Any suggestions? 72 olds cutlass
Old Jun 22, 2018 | 06:14 PM
kbdecatur's Avatar
I’m using Napa 7555 v belt. This is my 3rd belt.
Old Jun 22, 2018 | 06:23 PM
My2nd 69 442's Avatar
Check all you pulleys for a nick or bend. something is tearing you belt
insure belt is sitting down in pulleys
Old Jun 22, 2018 | 06:39 PM
kbdecatur's Avatar
I’ve checked the belts,they are sitting correctly. I’m beginning to think it’s the crank pulley. It’s the only belt squealing. It squeals when I turn on the a/c and mash the gas.
Old Jun 22, 2018 | 07:32 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Could you have a V groove mismatch or the wrong spec belt or both?
The belt needs to be the correct OEM size/spec. I am describing the depth and profile of the V shape. Most of the big box house of chineasium parts stores only have GP junk belts. They don't have enough "meat" in the V area.
What happens is the belt is only making good contact with the pulleys at the very top of sheaves versus gripping the whole V shape of the groove like the OEMs. That looks like what your belt is doing.
The pulley on the aftermarket pump could have the wrong size V groove, and is not compatible with the Olds OEM pulleys??
Check with Year One or Fusick for the right spec belt. The other problem could be an overcharged system. That will make the pump harder to turn. Check the belt spec first then see what the high side pressure is doing.
Have you discussed this with Vintage Air?
Old Jun 22, 2018 | 07:58 PM
kbdecatur's Avatar
Could you have a V groove mismatch or the wrong spec belt or both? No I haven’t called vintage air. I’m going to look into the system being overcharged. I have the exact same size that’s on the vintage air paperwork. I can say that the belt sits down in the groove a tad and that could be the reason it’s not gripping when I give it gas.
Old Jun 22, 2018 | 08:01 PM
kbdecatur's Avatar
Vintage air
Where can I purchase an OEM belt?
Old Jun 22, 2018 | 09:58 PM
Give Rock Auto a try. You’ll find discount codes on this site
Old Jun 23, 2018 | 07:22 AM
Let's back up. Do you KNOW it's the A/C belt? Squealing is usually caused by the PS pump belt. Temporarily remove the A/C belt and see if it still squeals.
Old Jun 23, 2018 | 07:50 AM
kbdecatur's Avatar
Yes it’s the ac belt when I switch it on it goes haywire..
Old Jun 23, 2018 | 08:34 AM
Year One or Fusick.
https://www.yearone.com/Catalog/1964...elts-.-v-belts
https://www.fusickautomotiveproducts...s.asp?dept=151
Dont see it call their phones
Old Jun 23, 2018 | 12:30 PM
TripDeuces's Avatar
V belts ride on the sides of the belt. If it bottoms out in the groove it will squeal.
The edges of your belt look bad too like the pulleys aren't aligned or are riding too low. I prefer to see my V belts either flush with the outer edge of the pulley or just proud of it.
In your case I would go with the next wider size. This will require I resizing check of the belt.
deaddds
Jul 31, 2019 07:33 PM
87Brougham307
Feb 18, 2019 09:30 AM
Del70
Oct 23, 2018 10:13 AM
1970cs
Oct 18, 2016 03:52 AM
442much
Jul 11, 2010 02:52 PM
