Today's brainstorm
Today's brainstorm
I need a quick brainstorming session here:
Customer's car: 1970 cutlass. 350.
In for a complete tuneup because it cranks but doesn't start.
So far I have put in the new coil, new points, new condenser, new battery, plugs, wires, cap and rotor.
This thing cranks and doesn't start. I ran a new yellow wire from the R terminal of the solenoid to the + side of the coil. Reads 11 volts. But when cranking, there's nothing. Coil is not generating a spark.
Purple wire from the S terminal into the firewall is in good condition as far as I can see it before it disappears into the harness.
Check + side of coil with key on...should be voltage there thru resistor wire. Purple wire on solenoid runs from key start position thru neutral safety. If this was the problem starter would not crank. Smaller yellow wire on solenoid provides 12V to coil while cranking. Points must open and close for spark. With key on you can manually open and close points and should have spark from coil to ground.
Also, you have verified that the timing chain hasn't jumped, haven't you?
.020" and closes at the peak of the distributor cam. I haven't torn it apart to look at the timing chain marks yet. Hoping not to
Take a #12 wire direct from the battery to the positive side of the coil and see if it starts. Do no leave it running if it starts this is just a test. If it does start then your resistor.
Could be that the starter soleniod is bad (not closing the contacts on the S tab
Nailhead 88
July 15th, 2008 02:01 PM
mumpspro
September 24th, 2006 11:03 AM
