67 or 68-69/ 70-72? Bulbs or bulb sockets? 67 yes to both the bulbs and the sockets. 68-72 no to both the bulbs and the sockets. The 68-72 standard clock uses a push in socket and 1/4 turn bulb. the 68-72 tach uses a push in style bulb and a special socket that is larger than the sockets in the speedometer or fuel pod. These are specific to the tach.
See pics below showing the back side of a set of 68 rally pack and you should be able to see the differences in the sockets.
If your question was: Can you plug the connector in the dash harness that would plug into the harness pictured above into the tach to power the tach lights? then the answer is yes.
