tic toc tach?
tic toc tach?
I have a '72 Cutlass with the factory dash, idiot lights on the left, speedo in the middle, and a blank space where the clock/tach is supposed to be. Is there any place that sells the original tach? Or which tach will fit in that spot? Any help appreciated.
Walt
Walt
You can get them re-popped with or without the gauges on the left. I think the set with the gauges is around $600. You might be able to find a tach by itself for $250-$300. I think if you found one for $200 it would need some work.
There is also a company selling just tachs to fit that have the "factory" appearance to them but don't have a clock and never came in these cars.
