testing oil pressure sensor
Old Sep 8, 2009 | 06:53 PM
ej69's Avatar
just installed engine and front light harness on 69 cutlass and all idiot lights illuminate when turn key one click, except brake and oil. car was a mess before resto, so not sure if worked prior, but new harness and new sensor. how can i test sensor. i haven't checked bulbs yet. by the way, how hard is it to access the dash bulbs for idiot lights?
Old Sep 9, 2009 | 03:50 AM
Yellowstatue's Avatar
Smile Testing
The idiot lights are easy to reach, just have to be gentle around the plug...to check the oil light, disconnect connector from sender and put a ground on that wire and the light should be on...same drill for the brake light at the distribution block and also at the P-brake switch...
Old Sep 13, 2009 | 03:06 PM
ej69's Avatar
thanks for help, i found two dash bulbs bad and was able to get brake light to work when activating e-brake and grounding wiring to brake distribution block. it will not light when plugged into block (this should light when key turned correct?) does this mean brake sending unit bad?
also, i grounded wiring for oil sending unit and even w/ new bulb cannot get it to light. any ideas
Old Sep 14, 2009 | 05:56 AM
Lady72nRob71's Avatar
Originally Posted by ej69
...grounding wiring to brake distribution block. it will not light when plugged into block
This is normal and means the distribution block is good. There is no "ignition on test" for the brake idiot light (that I know of), aside from setting the parking brake...
Have you done a good inspection of the instrument cluster and checked /cleaned the connector contacts on it?
Polish up the bulb contact areas also - I have seen many times where new bulbs do not work due to not-too-evident corrosion on the metal contact areas.
Old Sep 14, 2009 | 07:20 AM
ej69's Avatar
thanks for help, wish i found this site 6 months ago when is started chassis/drivetrain resto. i thought all idioit lights illuminated when turned key, letting you know they worked. i'll look at oil send bulb as sender and harness are both new. again thanks.
Tim305
Apr 29, 2014 03:36 PM
dacutty
Mar 28, 2014 09:01 AM
nanardos
Sep 1, 2013 09:41 AM
foreverolds
Dec 1, 2012 07:07 PM
Olds64
Oct 13, 2010 08:04 PM
