SUN blue line gauges light repair
Old Mar 22, 2025 | 07:19 PM
OLE442's Avatar
On my oil and water temp gauges, it looks like the light for each and the tack has one wire coming from the bulb socket. I assume that is 12 volt power so how does the light ground without a second wire. Also, it appears that you have to take to cover off to replace the bulb....what a pain. I added the oil temp gauge and it did not come with a light so I bought a generic one to install. The Super Sun Tach has a light that works but the two gauges have no light. One is missing and the other must be burnt out. I figure now that I have it restored, I might get caught driving it at night. Still trying to fix a few electrical items and I'm not an electrician....LOL!
Old Mar 22, 2025 | 07:40 PM
With a single wire one has to assume the ground side would be the case and mount.
Old Mar 22, 2025 | 08:41 PM
70sgeek's Avatar
'72 Cutlass ragtop
The metal casing of the gauge (or its mounting bezel if that is metal) should ground to the dash if bolted metal to metal - if however you mount the gauge to a non-metal surface, you should be able to run a jump wire from one of the gauge mounting post bolts to another ring terminal bolted to some other metal part of the dash to create a ground.
Candyman68
Jun 26, 2024 01:35 PM
Alex Cat
Jan 13, 2020 02:55 PM
rhett838
Aug 23, 2016 11:34 AM
68442Convertible
Jul 5, 2012 10:25 AM
stevengerard
Sep 13, 2010 05:57 AM
