Starter mtg. on 64 StarFire??
HELP!! I'm looking at a 64 StarFire coupe to replace "lost" Cutlass in Fire, will want to swap out the "roto" Hydromatic as these were a "bummer' transmission!! does the starter bolt up to the engine OR to the bell housing on this yr.?? Waiting for replacement traile before I go look at this coupe. will likely go the O/D trans. route. Did this a few yrs. ago on Pontiac Catalina & got lucky, block was pre drilled & tapped for later starter, org. one bolted to B'hsg. Thks. Pete
Oldssupreme
Feb 3, 2013 06:26 AM
Oldssupreme
Feb 3, 2013 06:24 AM
