Spark Plug Wire Holder
The 4 spark plug wires on the drivers side of engine are held up by the plastic holder.
But in the passenger side the 4 wires just lay on top of the coolant lines to the heater core. I do not see a bracket on the valve cover to install the holder. Am I missing this part?
What is your car?
I think only the big cars had a "bracket" to hold the wire holder on the driver side. Never seen the Cutlass or 442 with the bracket, only the holder. I am sure this is correct for 70-72 but can anyone confirm this for other years of Cutlass?
My '68 4-4-2 has the same kind of metal bracket that bolts on with a valve cover bolt and then the 4-wire divider mounts onto the metal bracket for the driver side - just a wire divider for the passenger side. I didn't see (or have) that bracket on my '69 on the driver side when I restored it. The '69 just had the 4-wire dividers on both sides.
Randy C.
Randy C.
