Solved my dragging starter issue
Had a problem starting the engine when it was cold. It would drag to the point you would think it was not going to start. Did better when it was hot and even heat soaked. I guessed it was the additional friction of being cold. I increased the cable size on the + and - and cleaned all connections. The battery was a 3 months old Diehard with 800 CCA and even though I kept checking and finding the voltage drop down to 9 volts I had trouble believing that was the problem. Took the battery and had it load tested, it had a bad cell. Bought the Odyssey battery below and now the car cranks perfectly, hot or cold. Best $400 dollars I have spent on the car. 1000 CCA at 32*
I bet yours spins good with the 9510 and AGM battery
Michael_
July 21st, 2023 07:18 PM
