Red or black?
Red or black?
Getting ready to replace the positive and negative battery cables on my '72 Supreme and in the process I'm going install the alternator cable cap. I see they're available in both red and black...how do I know which one I need?
Maybe the caps are just basic generic caps which fit many applications & not simply alternators? I don't know. I know you if were to purchase an alternator for a Nash, Packard, Studebaker (some others including many older European vehicles) you'd be looking at a positive ground system instead of a negative ground system.
If I remember correctly the Red is for the OEM high (63 amps-Convertible) Alternator and Black is for the OEM Low (27ish amps) Alternator
I think this is noted in the Assembly Manual (at work so I cant check) I think that is how I figured out which one to use when I replaced my Alternator (Old one was red also)
I know I saw it somewhere but for the life of me I don't remember where
I guess if you are doing a show car and looking for points it would matter, otherwise I guess go with what you like
Pretty certain the ASM lists only a red cap & I thought they were all OEM 63amp? I never thought there was delta between convertibles & others as you suggested. Maybe so.
My car is hours away, and I haven't worked on it for a while. But I think my 69 has a black cap. I think Pontiacs used red caps. I think the plastic washer that the cap snaps on to, is the color the cap should be. That's just from memory, and I could be wrong.
