Rear Lights
Old May 6, 2008 | 08:41 PM
gumbyssfakee's Avatar
Rear Lights
I have a 71 cutlass 4dr and for some reason the rear lights will not shut off. I have to just unplug the whole setup because they will stay on with the engine off keys out and all. Yet the signals work and they get brighter when i hit the brakes. The front lights will shut on and off as usual. Any idea why this is happening?
Old May 6, 2008 | 09:23 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I had this happen to me twice.
First time, The shop that flushed my coolant and rear differential fluids installed the wrong light bulbs in the taillight sockets and they were shorting out. I appreciated them going the extra mile and doing that for me, but.....
The second time, The stop light switch behind the brake pedal shorted out.
Old May 7, 2008 | 04:48 AM
Oldsguy's Avatar
Past Administrator
If the tail lights are on when the headlamp/tail light/interior dimmer switch is in the off position you may have a bad switch. There should be no 12 volts available to the tail light socket at all with the switch in the off position (except when the brake pedal is depressed). For the lights to be on and get brighter with the brakes applied you would need both a bad brake switch AND some wrong lamps installed in the sockets.
Old May 7, 2008 | 10:43 AM
Everything on the car has been there for months i havent changed any bulbs etc, but i will look into the the switches and see if thats the problem thanks
scooter123
Sep 28, 2013 07:32 PM
65droptop442
May 5, 2013 12:21 PM
devmar07
Feb 23, 2012 04:40 PM
oldstuff
Sep 13, 2011 08:03 AM
Sid
Sep 10, 2010 02:33 AM
