Rally gauge sending unit connector
Old Jan 18, 2026 | 04:56 PM
Dannick's Avatar
Hello all, I’m converting my 72 Cutlass from the warning lights to the gauges. I removed the warning light/fuel gauge, re-pinned the connector moving the wires to the proper locations and installed the gauge unit. Moving under the hood I installed the gauge sending units for both the temperature and oil. The wiring harness connectors for the warning lights temp and oil pressure sending units are different and I can’t plug into the new sending units. The gauge temp sending unit has a pin or nail head type vs a spade or blade type for the warning light sending unit and the gauge oil pressure sending unit a blade type but with a bent over hook on the end. Short of having to buy a new engine wiring harness and I can’t find the proper connectors. Any help would be greatly appreciated! Thanks!
Old Jan 18, 2026 | 05:29 PM
Loaded68W34's Avatar
72 had an extension wire to connect from the warning light plug in the harness to the gauge sending unit.
Lectric Limited has reproductions for $27.00
https://www.lectriclimited.com/produ...xtension-wire/
The black plastic end on the temp sending unit wire has a slot to use with the pin-type sending unit. You can de-pin the connector from the plug and grind a slot in your original, or buy a slotted plug to put on your original terminal.
https://www.summitracing.com/parts/a...MaAu-XEALw_wcB
Old Jan 18, 2026 | 05:57 PM
Dannick's Avatar
Thanks for the info! My current connector end for the temp sending unit is blue. Wonder if that is correct for a gauge package engine wiring harness and?
Old Jan 18, 2026 | 06:01 PM
Maybe post some pics of the connectors you have now.
Old Feb 5, 2026 | 08:48 AM
derone's Avatar
I did the same swap, but I sourced the sensors from Ames off their GTO catalog so I wouldn't have to change any sensor connectors.
May 17, 2025 07:39 PM
pacekar
Jan 24, 2016 07:42 AM
72OldsRocketMan
Jul 13, 2014 07:38 AM
my442conv
Nov 9, 2013 10:10 AM
Del70
Nov 3, 2012 06:24 AM
