question about distributors please
what happens when i put a distributor from a 1969 455 2B into a 1969 350 4B?
ive tried looking at the distributor interchange section in the tech section, but dont quite understand what the I#s mean.
it boils down to this - i just bought a 68 cutlass that has a 69 replacement block in it from a dealership warranty repair
it has a single points type distributor in it but i do not believe it is a factory olds distributor - more on that in a second
i bought an ignitor 2 electronic ignition and coil for it
i pulled the air cleaner housing off tonight to start on it, and when i took a closer look at the distributor, it has no vacuum advance cannister on it
and i do not believe it to be an oldsmobile distributor because it doesnt look like the photos ive seen, and it has no numbers on it, nor does it have a name brand on it.
the car works fine as is, but im a dummy with the points, and dont want an HEI, so i thought the ignitor 2 was my answer
now with this oddball distributor, id prefer a factory olds dist. with a vacuum advance cause its going to be a car me, and my wife will drive.
so, i see a distributor on ebay that has numbers on it that says it came from a 69 455 with a 2b carb on it - what happens when i take that dist. and install it into my 350?
thanks
Mike
![Embarrassment](https://classicoldsmobile.com/forums/images/smilies/redface.gif)
thanks
Mike
........ i bought an ignitor 2 electronic ignition and coil for it ........
Norm
rtpassini
December 1st, 2012 11:10 AM
