Power window harness
Old May 17, 2014 | 02:21 PM
oldsmobilty's Avatar
Does anyone know if the power window harness is the same on A body as B(70-72)? I know the plug to the master switch is different but other than that are they the same? I am missing the section that runs from the driver door to under the dash. I have one in a 98 and don't want to go through the trouble of removing it if it's not the same.
Old May 17, 2014 | 03:22 PM
Absolutely not the same, though you can compare plugs, and some of those may be the same (a 98 has different plugs for the switches because the switches are different).
stlbluesbrother
Feb 14, 2015 10:25 PM
pfergy600
Feb 6, 2015 02:32 PM
jugdish
Aug 18, 2011 09:57 AM
Trans Am Depot
May 17, 2011 09:39 PM
69984yoas
Apr 13, 2011 07:44 PM
