Plug connections to steering column
Old Feb 11, 2017 | 08:51 PM
Steve70's Avatar
Restoring a 1970 cutlass convertible. On the top side of the steering column, there is a white plug (towards firewall) and a black plug (towards dash). There is presently only an orange wire in the top middle position, but I have a dangling green wire with a spade that's taped along side it. The only choices would be middle row left, middle row right, or bottom row left. Can someone please tell me which hole (looking from wire side of plug) the green wire goes into?
Old Feb 11, 2017 | 10:45 PM
stevengerard's Avatar
I'll try to take a look at my car for you. IIRC the orange is for the convertible top don't remember a green
Old Feb 12, 2017 | 04:51 AM
Steve70's Avatar
Thanks Steven.
I also have another question. There is a short 3 wire harness coming off the convertible top switch. One of the wires has a ring connector on it, and I'm pretty sure it goes through the firewall then gets connected to the 40A circuit breaker in the engine compartment. Is there a specific location where this wire should pass though the firewall? Maybe a measurement from a corner of the fuseblock?
Thanks much for your help.
Old Feb 12, 2017 | 06:10 AM
This schematic has been posted here before, but I don't recall by whom:
The green wire is the ground wire that causes your "HOT" light to come on when you crank the starter.
See the Ignition switch pinout at the right, on the bottom edge.
(By the way, "Open in a New Tab" or "Download Target" for the full-resolution file).
Old Feb 12, 2017 | 06:51 AM
If you have a gauge instead of a light that wire is removed so as not to peg the gauge every time you start the car.
Old Feb 12, 2017 | 06:55 AM
... A factory gauge...
Old Feb 12, 2017 | 06:58 AM
Another assumption on my part...
Old Feb 12, 2017 | 07:11 AM
tru-blue 442's Avatar
Old School Olds
I don't know if this helps you or not.
Old Feb 12, 2017 | 06:11 PM
If the car had idiot lamps the green wire provides a vround the the temp light when the key is turned towards the start position.if the car has gauges i dont think the green wire was even in the harness. Has someone converted this car.to factory style gauges?
Old Feb 13, 2017 | 05:47 PM
Steve70's Avatar
Ok thanks guys. I'm embarrassed to say that a year ago, I converted from standard gauges to Rally gauges, and now I remember disconnecting this myself.
starfire
Dec 9, 2021 08:21 PM
317Cutty
Jun 18, 2014 10:53 AM
ros6872
Mar 28, 2014 09:48 AM
oddball
Mar 4, 2014 06:42 AM
ds00469
Jan 25, 2014 05:12 PM
