Please help me 1955 Oldsmobile Super 88
Old May 16, 2021 | 03:45 PM
Katefireoved's Avatar
I am trying to order a wiring harness kit for a 1955 Oldsmobile Super 88 2 door, I was trying to surprise my husband but I have no idea what to order or where.
Old May 17, 2021 | 07:05 AM
Tedd Thompson's Avatar
Try Fusick if you can't get one at your local parts house it may have to be ordered and could take a day or two to come in.
This may sound strange and I hope you understand what I'm about to explain but a Ford 360 has the same length wires and will work just fine but the distributor is in the front of the engine the Old's is in the back but if you just reverse the wires(turn the whole mess around) everything will line up just like it was made for it.... Best of luck...Tedd
Old May 17, 2021 | 09:02 AM
rocketraider's Avatar
Oldsdruid
Do you need spark plug/ignition wires as Tedd says, or do you need the whole car electrical harness that powers lights, horn, starter etc?
Rhode Island Wiring Service www.riwire.com, Lectric Limited www.lectriclimited.com, and M&H Electric Fabricators www.wiringharness.com are a few that come to mind. They can supply the original style harnesses with the correct wiring colors and terminals that FIT RIGHT.
Painless Wiring is also an option but I'd stay away from that unless the car is modified with a lot of aftermarket electrical loads.
Up front- some of these are running behind due to covid, and wiring harnesses are not inexpensive. But if your car's wiring is at all questionable, it's a good and wise purchase.
Old May 20, 2021 | 06:12 PM
Good catch Glenn, I was thinking plug wires all the way even though the post clearly states wiring harness...... Read twice post once.....Tedd
Old May 21, 2021 | 06:09 AM
Oldsdruid
Now if Kate would come back and let us know if we've helped at all...
Estew1
Jul 17, 2019 09:16 PM
harwooddan
Apr 15, 2018 06:59 PM
nj67
Mar 8, 2016 06:52 AM
malatu
Mar 23, 2008 03:39 PM
