Pic of '68 Cutlass RH headlamp Harness Routing
Old Mar 31, 2019 | 08:10 AM
bry593's Avatar
1968 442 Convertible
I am installing an AAW factory fit harness. I can't find the illustration of the wire harness routing in the assembly manual. Harness seems a bit jumbled the way I have it routed, so probably did it wrong. Note that someone had rerouted factory harness incorrectly before I got the car.
I'd appreciate it if someone could take a pic of this area so I can see the factory routing.
Old Mar 31, 2019 | 08:51 AM
Steven Hall's Avatar
​​​​​​​do you know if a 67 cutlass is the same I can go snap a few pics of mine I believe it's all ran the same way the factory did it down the driver side fender to the left head lights under the core support to the right head lights
Old Mar 31, 2019 | 09:06 AM
rcorrigan5's Avatar
Randy C.
Manual section 12, page 137 of the assembly manual shows the routing of the wiring harness to the front head lamps and horns.
Randy C.
Old Mar 31, 2019 | 11:09 AM
bry593's Avatar
Thanks Randy. My crazy manual is printed wrong and every other page is upside down. But I do have that page ☺️.
That's the way I have it routed. I think the AAW harness might be a little different from factory, and this is causing the jumbled fit. I can live with it.
NotDads442
Jul 11, 2019 01:27 PM
XTREMEGSXR
Jun 5, 2012 10:29 AM
jo75olds
Jun 14, 2011 08:34 PM
mycut
Aug 25, 2010 07:49 AM
Bunser
Jun 3, 2010 05:41 PM
