No power to anything
Old May 31, 2025 | 10:17 AM
84delta88royalecoupe's Avatar
I recently rebuilt the transmission in (username), installed as normal but when I put the battery in I don’t have power anywhere. I got the two ground wires bolted where they’re supposed to be but otherwise I don’t have a clue what to do. Any suggestions?
Old May 31, 2025 | 10:23 AM
Tell us what year, model car is the best start.
Old May 31, 2025 | 10:31 AM
1984 delta 88 307 motor th2004r trans, like I said, username mostly
Old May 31, 2025 | 10:38 AM
Do you have 12VDC at the horn relay distribution block?
Old May 31, 2025 | 10:40 AM
I don’t know I’ll check that out when I can, thanks
Old May 31, 2025 | 11:57 AM
69CSHC's Avatar
Originally Posted by 84delta88royalecoupe
Any suggestions?
Silly as it may seem, check if the battery is dead. If not, going over every connection that has been in play would be the next step. Even if you already did it. So forth and so on. Up the difficulty of solution ladder.
Old May 31, 2025 | 12:37 PM
Alright, no power to the horn relay but I do have power to the glove box for some reason, what's that sound like
Old May 31, 2025 | 01:11 PM
69CSHC's Avatar
The glovebox takes the least amount of power. No horn, the battery is just about dead ...
Old May 31, 2025 | 01:29 PM
Just charged the battery, I found a couple snapped wires near the starter that might have something to do with it
jmcghee
Jan 23, 2025 06:08 AM
JackBronson
Aug 10, 2019 04:07 AM
64Rocket
Jun 19, 2012 11:55 PM
Beob
Feb 5, 2010 10:09 AM
John G. Nelson
Nov 3, 2009 05:52 AM
