Neutral switch
Old Jun 16, 2018 | 04:17 PM
jwr7042's Avatar
Neutral switch
How can.i check to see if switch is working or not
Old Jun 16, 2018 | 04:28 PM
72455442RA's Avatar
Hello
pm sent
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
this is your buddy for this one ...
is your car not starting ? you can jump the purple wires to
bypass the switch...
year and model ? column or console ?
Old Jun 16, 2018 | 06:27 PM
With the transmission in park or neutral, you should see voltage on both sides of the switch when you turn the key to start with the wires connected. Or you can remove the 2 purple wires and you should see continuity with an ohm meter.
Old Jun 19, 2018 | 09:15 PM
cjsdad's Avatar
Put the shifter in LOW and turn the ign key to the start position. Move the shifter slowly through the gear selections until the starter spins. If the shifter is in the neutral position when the starter engages, you know that part of it works. Continue moving the shifter towards PARK. If the starter engages when the shifter reaches PARK then you know the NSS is good. If the starter engages in any other position, it is bad.
The Safety Switch only operates with the shifter though. If the linkage to the trans is not adjusted correctly, the engine may still start while the trans is in gear but the shifter is in the PARK or NEUTRAL position.
If the starter does not engage with the above testing, you will need to use a volt meter to check for power after the switch. If you have power going through the switch and the starter does not engage, you most likely have a bad starter.
If you can't fix it with a hammer, you have an electrical problem!
navvet
May 12, 2013 12:23 PM
Twilight Fenrir
May 24, 2011 06:26 AM
roy341
Jun 27, 2009 07:26 PM
Daniel2008
Jan 1, 2009 07:43 PM
bcg88
Nov 18, 2007 01:57 PM
