Need help with installing a mini starter
Old Feb 28, 2026 | 03:39 PM
Pace70's Avatar
I bought a Powermaster 9510 XS mini starter, for my 1970 Oldsmobile 442 with a 455 engine. The powermaster has 2 terminals. My stock starter has 3, positive post, run wire, and ignition wire. I was told that the powermaster should bolt right up, and work as the original does. So, the problem. I have 3 wires, and 3 terminals on the stock starter, and only 2 terminals on the new starter. Any suggestions? Thanks!!
Old Feb 28, 2026 | 04:10 PM
68442CONVERTCO's Avatar
Aloha, Tony
Watch this :
Old Feb 28, 2026 | 05:59 PM
It depends on what distributor you’re using. If it is not points and you have full battery voltage running to the coil, simply cap the yellow wire going to the coil+ terminal from the solenoid R terminal.
Old Feb 28, 2026 | 06:14 PM
Pace70's Avatar
Thank you all for your replies, I now know that I need a diode on the run connection. Again, thank you so much!
green1972
May 29, 2022 07:20 AM
driskdg1#
Jul 12, 2021 01:56 PM
Kyle's77cutlass
Jun 16, 2019 09:19 PM
gtaa9
Jul 16, 2015 11:24 AM
88hurstolds
Jan 11, 2013 07:43 AM
