My electrical hardships
Old Feb 4, 2012 | 02:49 PM
Jetstar 88's Avatar
Whenever I turn on the dash lights, my fuel gauge drops by 3-4 gallons. This also happens when I use my turn signals. What could be causing this?
Old Feb 4, 2012 | 04:35 PM
Highwayman's Avatar
Anytime I see erratic electrical problems I think bad ground.
Old Feb 4, 2012 | 06:12 PM
Lady72nRob71's Avatar
Or other bad connections under the dash and at the gauge clusters.
Old Feb 4, 2012 | 06:35 PM
Rickman48's Avatar
Carry a fire extinguisher until fixed!! Battery cut-off would also be good!
An ounce of prevention-------
Old Feb 7, 2012 | 11:26 AM
StarGeneral's Avatar
My car does this as well sometimes after starting it...the gas needle will go all the way to the fullest possible mark I just give the gauge a sharp rap with my knuckles and it goes back to where its supposed to be...
Old Feb 7, 2012 | 12:33 PM
rocketraider's Avatar
Oldsdruid
Every 63-64 FSC I've ever seen does this after so many years. Both my Starfires do it. Aggravating, but not enough to make me tear the dash apart.
I expect unplugging the printed circuit pin connectors and lightly cleaning the pins would help, but there's a risk of breaking those pins and that's no fun.
Old Feb 8, 2012 | 05:00 AM
81 regency's Avatar
President Blue/Grey OCA
electrical problem
Hello Everyone,
Ground, Ground, Ground!!!!
While most of the world worries about am I getting power it is no good without ground!
I could be a bad printe circut board or wire wound resistor on the instrument cluster board, (also called a regulator) but ground the cluster dieactly to the battery with a jumper wire and I bet the problem goes away!
Good luck
Rich
jf857
Apr 28, 2006 07:24 AM
BOB W M
Apr 7, 2006 06:30 PM
PetChemMan
Dec 15, 2005 04:15 PM
86in
Feb 9, 2005 09:49 AM
NV WIDOW
Sep 1, 2004 04:34 AM
