MSD Ready to run
Old May 25, 2013 | 02:54 PM
70cutty's Avatar
Beer Connoisseur
MSD Ready to run
I am trying to install MSD Ready to run distributor to replace the points dist. I am a little confused. After reading numerous threads about hooking up HEI couple of things are still not clear to me.
I ran a 12 gauge wire from the pink wire under the dash, which gives me full 12v when ignition is on, to the distributor.
Do I keep the existing wires that are hooked up to the coil and run full 12v directly to the distributor or do I run a full 12v to the coil and then hook up distributor to the coil like in MSD instructions?
I have NGK Iridium spark plugs, how much should I gap them?
I've read anything from .040 to .060 so I am not sure.
Please help. Thank you.
Old May 25, 2013 | 03:15 PM
Orange is to the coil (-) terminal.
Red is to the +12V source and to the coil (+) terminal.
Black is to ground.
Hook the +12V wire to the coil (+), and the Red wire to the coil (+).
Source
Old May 25, 2013 | 03:25 PM
There should have been 2 wires on your old coil. One was the resistor wire, the other was from the starter to provide 12v while in the start mode. The resistor wire I would just cap and stow. The wire from the starter in some cases is needed as the start and run circuits are isolated by the ignition switch, so you may need to connect it to the "batt" terminal on the HEI.
I gap my plugs at .045, but you can go as big as .060, the bigger the gap the hotter the spark.
Old May 29, 2013 | 08:26 PM
70cutty's Avatar
Beer Connoisseur
Thanks guys. I am gonna install it this weekend.
Old May 29, 2013 | 08:43 PM
Let us know how you make out. By the way you need to set your timing a bit different because of the advance curve on the HEI. Your engine may want more initial advance. Also watch the for pinging when you connect your vacuum advance.
Do you have a dial type timing light?
Old May 29, 2013 | 09:23 PM
70cutty's Avatar
Beer Connoisseur
Yes I just bought one. What should I set initial advance at?
Old May 30, 2013 | 03:54 PM
70cutty's Avatar
Beer Connoisseur
What do you mean it's not a HEI distributor??
Old May 31, 2013 | 04:48 AM
70cutty's Avatar
Beer Connoisseur
Originally Posted by ah64pilot
1. Did you buy it new?
2. What is the part number?
3. Does it have instructions?
Yes it's brand new.
MSD 8529
Yes
Old May 31, 2013 | 09:19 PM
70cutty's Avatar
Beer Connoisseur
So I don't need this wire for full +12V, just hook up to the coil the way it is?
Old Jun 2, 2013 | 07:21 PM
70cutty's Avatar
Beer Connoisseur
Should I hook up the full +12V wire to the coil or just install it like points distributor??
Old Jun 2, 2013 | 07:44 PM
dc2x4drvr's Avatar
12v to the coil.
Old Jun 2, 2013 | 07:51 PM
70cutty's Avatar
Beer Connoisseur
Thank you.
Old May 29, 2018 | 10:42 AM
Rocketman!442's Avatar
Old May 29, 2018 | 10:43 AM
12 BTD initial, 36 total all in by 3400. I think I used the two light blue springs.
Old Jul 27, 2018 | 09:08 PM
Gone Johnson's Avatar
Here's a related question:
The MSD coil (MSD Blaster 2) that goes with this distributor, has an option WITH ballast resistor, or WITHOUT ballast resistor. My setup is already HEI (1972 Olds Cutlass w/350/350, 1977 GM HEI already installed), so, its just one 12V wire from IGN on fuse box, to HEI. Do I even need the ballast resistor with my setup?
Old Jul 28, 2018 | 06:08 AM
This is what it should look liken no ballast resistor:
Instruction sheet
http://documents.msdperformance.com/8529.pdf
Old Jul 28, 2018 | 11:38 AM
Okay great, no ballast resistor. Got it yay, I get to save myself 6 or 7 Bucks!
Old Mar 26, 2019 | 09:19 PM
Thanks Gone Johnson, Ive never had so much power than since I installed this distributor. What a smooth running engine!!
Old Mar 26, 2019 | 09:38 PM
Awesome
Old Mar 26, 2019 | 09:50 PM
Awesome
Thanks oldcutlass, the help was invaluable
rick442
Jun 11, 2018 12:20 PM
442Dave
Jan 7, 2012 07:28 AM
slowolds
Jul 16, 2011 09:15 PM
mp71conv
Oct 21, 2007 10:49 AM
J'ville
Jun 10, 2006 03:13 PM
