manuals
Old Nov 4, 2012 | 06:04 AM
wizard's Avatar
manuals
I have the 1984 oldsmobile shop manual , and in there are references to the "ETM,"which is the "electrical troubleshooting manual". I haven't found a source for it yet. Does anyone know if or where it might be found ??
thanks
wizard
Old Nov 4, 2012 | 06:15 AM
Faxon has a copy. $15 in fair condition, $30 in very good condition.
Old Nov 4, 2012 | 07:18 AM
Or, learn how to use the advanced search function on ebay. There are currently 25 of the 1984 ETMs for sale there. The cheapest is $4.99.
Old Nov 8, 2012 | 06:15 AM
wizard's Avatar
I now have the electrical troubleshooting manual plus the supplement for all 1984 olsmobiles. I'm a little disappointed in that the diagrams don't quite show what I'm looking for. there is a diagram for the standard wiper/ washer switch , and a diagram for the wiper/washer (pulse).that's fine , but these diagrams do not show the connections as used on the cruise control lever (stalk). and the cruise control ( multifunction lever) diagram does not show the connections which are included there for the wiper/ washer control. I'm having to try and figure out the system by putting two and two together. I think there is a problem in the "stalk " wiring , since it controls the "hot" side of everything , but it will take some time I guess. If the "stalk' on my car is defective That unit is used on many ,many GM cars from the 80's, including buick, olds, and pontiac , so I may be able to get a good used one. Dorman has new units but the price is around 100 dollars, so it is a little expensive . I'll check the local junk yardsto see what I can find.
It also appears there may be a third manual for this car , a "body" manual . I'll have to look into that also.
Well , enough of this for now .
You folks all have a nice day.
wizard
Old Nov 8, 2012 | 07:44 AM
cfhcar's Avatar
the lever with cruise control twist into the wiper switch in the steering column replacement procedger in repair manual. connector picture in emt manual after wirring diagram with imformation on how system works. cruise wirring very small and runs down the column by its self look under cruise in wirring book.
Jolly Green
Apr 25, 2008 02:18 PM
desert442
Jan 22, 2008 10:43 AM
