Lost lights while driving
Old Jul 10, 2015 | 11:16 PM
help442onguam's Avatar
Greetings everyone
This is kinda stressful , I hope i can find some help , so I'm driving at night and my lights slowing fade to stop working and I park my car then it won't start , I haven't tried to troubleshoot yet it's a bit late but hopefully Somone can chin in please
Old Jul 11, 2015 | 02:45 AM
JPMDaddy's Avatar
sounds like battery died... you may have a bad alternator not charging the battery properly, eventually the headlights would then run the battery dead....
depending on the age of battery, it may hold a charge again once the charging system is working or you may need a new one along with a new alternator.
auto parts stores can test both....
Old Jul 11, 2015 | 04:19 AM
Octania's Avatar
A voltage reading on the system, like at the battery terminals, would be a good start.
Alt belt loose or missing?
Terminals on battery not corroded or loose...
what year and model?
Old Jul 11, 2015 | 04:22 AM
svnt442's Avatar
Sounds like a classic charging issue to me. Depending on the car it could be the alternator, voltage regulator, both or a loose/missing belt.
Old Jul 11, 2015 | 04:25 AM
1970cs's Avatar
Lansing built
X2 on what Chris said, more clues! The crystal ball needs help.
Pat
Old Jul 11, 2015 | 04:42 AM
I agree with the above. Sounds like a charging issue.
Old Jul 11, 2015 | 06:35 AM
stellar's Avatar
stellar
Not enough EMF to overcome the resistance. Add emf to the battery and check system.
Old Jul 11, 2015 | 06:52 AM
pogo69's Avatar
morgan
alternator is kaput
Old Jul 11, 2015 | 07:13 AM
Simple troubleshooting first, as above...
Old Jul 11, 2015 | 07:21 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Before you rip the car all apart, make sure your alternator belt is tight. When I was in Viet Nam in 69-70, my wife had trouble with our 65 Grand Prix the whole year with the battery going dead. It was a loose alternator belt.
Old Jul 11, 2015 | 07:33 AM
jaunty75's Avatar
Do you have a voltage gauge or an indicator light? In either case, I would have expected the GEN light to go on or the voltage gauge to show a low number if the battery was being discharged, so you should have had some warning before the lights died and the car rolled to a stop at the side of the road unable to be started. The whole point of the indicator light or gauge is to warn you of a problem like this before it gets to the point it got with your car.
Old Jul 11, 2015 | 12:54 PM
I'm sure he wouldn't have driven it far if a warning light was on. And I'm sure he would have mentioned it in OP.
Old Jul 11, 2015 | 01:31 PM
jaunty75's Avatar
I agree he would have said something, but the point is, WHY didn't the GEN light or whatever go on? The type of problem he's describing is exactly the kind of problem that should trigger the GEN light or show up as a loss of voltage on a gauge. It seems that he has a problem with the warning light circuit as much as he has a problem with anything else.
Old Jul 11, 2015 | 01:56 PM
Thanks everyone , ok I jump my car drove it and the same thing happened so I'm guessing the battery is good its 3 months old . So its extremely frustrating because I just had the engine rebuilt and I don't want to ever visit the shop again that did the work because they will say I did something to it to avoid doing anything extra . So I'm leaning toward new alternater year 1985 cutlass broham
Old Jul 11, 2015 | 02:00 PM
Yes, I see ... good point. OnGuam, can you in fact confirm that no warning light came on?
Old Jul 11, 2015 | 02:02 PM
Have you put a voltmeter on the battery with the engine running?
Old Jul 11, 2015 | 03:07 PM
Octania's Avatar
New is not the same as good
assume no such thing
verify that the GEN or ALT lite comes on if the charging system is not working- e.g. ignition on but engine not started yet.
Apply the volt meter to the battery before and after starting the engine, note the readings.
Have alt and new battery tested at the local store as need be
Brand new battery can be bad.
Old Jul 11, 2015 | 03:11 PM
1970cs's Avatar
Lansing built
X2 on what Eric has said. Get the meter out and see if it's charging. It should read 12.6 volts sitting and rise as the RPM's rise to may be 14 and change.
Now we know what car it is, the alternator is internally regulated. Assuming nobody has monkeyed with it.
Pat
Gixxere
Mar 18, 2012 09:54 AM
time_machine
Sep 15, 2010 10:10 AM
jaunty75
Jan 27, 2010 12:59 PM
dan1s
Sep 11, 2009 02:49 PM
WasteOfMind00
Apr 18, 2007 08:10 AM
