lights/heater
lights/heater
I have a problem with the lights on my '78 delta 88 royale. When I turn them on, only the running lights come on, but if I mess with the dimmer switch and hold it just right, I can get either the low or high beams to come on. Once they warm up, the low will stay on, but it won't change to high. Eventually if I leave them alone, they turn on the high beams by themselves and they won't change back, but they flicker on and off as I drive. Also, as a side note, my heater blower works on low and the 2 medium settings, but it won't go to high. any help is appreciated
The headlight problem sounds like the dimmer switch. Is yours on the floor or on the column? The floor mounted unit is easy to replace. The column mounted unit may require you to drop the column for access.
