Lights in Dash
Old Sep 14, 2020 | 11:32 AM
Bobby455's Avatar
Lights in Dash
The lights that illuminate my clock and my speedo are all out. Do I need to pull the dash to replace them or am I able to access the bulbs from under the dash?
Old Sep 14, 2020 | 12:02 PM
rocketraider's Avatar
Oldsdruid
What year and model?
Old Sep 14, 2020 | 12:04 PM
Bobby455's Avatar
1971 Cutlass Supreme
Old Sep 14, 2020 | 12:33 PM
4speed455's Avatar
I doubt all the bulbs failed at the same time. I would start by checking the fuse labeled “4A INST LPS”. If that is good check if you have power on the grey wire that supplied voltage to the bulbs. If those are good it’s probably a ground issue. On 71 remove the gauge bezel and pull the pods out through the front no dash removal needed. The ground is supplied with metal ground straps on the dash the the gauge is mounted to.
Old Sep 15, 2020 | 06:02 AM
Bobby455's Avatar
When I bought the car two of them were already out. After 6 years the other speedo light went out. The only thing lit up now is the gage for the dummy lights. Idk if that helps or not.
tomwolfgram
Sep 3, 2020 03:19 AM
bcg88
Apr 28, 2012 11:02 AM
Redog
May 23, 2011 08:50 PM
2 door cut
Feb 15, 2007 01:45 AM
2 door cut
Dec 29, 2006 03:02 PM
