Lectric limited
Old Dec 27, 2022 | 12:31 PM
65droptop's Avatar
Lectric limited
looking for references on lectric limited if any of you have experience with them, sure would like to hear about your thoughts.
thanks
duane
Old Dec 27, 2022 | 12:45 PM
Tri-Carb's Avatar
I have purchased from LL many times without an issue.
Old Dec 27, 2022 | 02:49 PM
Loaded68W34's Avatar
I have a set of their dated spark plug wires on my Toronado.
Old Dec 27, 2022 | 04:53 PM
Trophyblue442's Avatar
I have purchased a lot from them for my corvette and 442. I replaced every harness including fuse block on my 69 442 with their stock replacements and everything fit perfectly. The only difference was for the tach. In the original harness the tach lead was run as a separate wire in the new harness they incorporated it into the harness.
Old Dec 27, 2022 | 06:23 PM
jensenracing77's Avatar
I have used them many times. I did run into a problem on a 70 442 engine harness that had a wire in the wrong pin location at the fire wall plug. For me it was not a difficult fix but I could see someone not good at basic electronics would have had a nightmare on their hands. I ran into another 70 442 engine harness that has the water temp and oil pressure sensor wires swapped on their lengths. I had to modify the harness for it to be factory correct. I done it myself because I am able to do it and and still make it look factory but I have no doubt that they would have taken care of it had I called and ask them. I also use their spark plug wires. I will continue to use them and even thought I did have those two problems I really like their products.
Old Dec 28, 2022 | 05:16 AM
35tac's Avatar
No problem with Electric Limited. For my 66 Cutlass convertible I had them provide a set of dated spark plug wires, a set of battery wires and rear light harness. They worked their butts of to provide excellent delivery times.
Absolutely would only use Electric limited for my Oldsmobile.
Wayne
Old Jan 4, 2023 | 06:06 PM
omy442's Avatar
I bought from lectric limited date coded plug wires and pinch clamp battery cables for my 68 and been on car for 15 yrs.. Have extra sets for my other project 68.
Nice quality.
Mader
Old Jan 16, 2023 | 01:14 PM
Pecosbill7's Avatar
Outstanding quality and very good people.
Old Jan 16, 2023 | 02:52 PM
VI Cutty's Avatar
Just ordered engine bay harnesses from them, looking forward to seeing them.
72 Post
Jan 17, 2023 05:11 AM
Supremecutty
Apr 24, 2020 11:33 AM
oldsman72
Jul 30, 2014 07:42 PM
7train
Jan 30, 2014 04:52 PM
mal1form
Jan 12, 2007 09:25 PM
