interior lites flicker
hey guys my 72 cutlass s interior lites flicker when either door is opened with the engine running, but are steady with engine off. i have checked around for good ground at battery to block & block to fire wall strap to voltage regulator base good clean & tight. any thoughts? thanks BILL
does it also do it with the door shut and the switch on and the engine running. if not the first thing i would check is take the door switches out and make sure they work good and not corroded.
Are the lights flickering on / off or is just the brightness changing ? If it's the brightness that's changing I would check the charging system voltage for a pulsation which could be caused by the voltage regulator.
Mine did that with the old mechanical regulatorm mainly on startup when current draw was higher after cranking.
It is a somewhat normal condition, due to the workings of the mechanical points in the reg.
The flicker disappeared when i changed to a solid state reg.
my regulator is old not a delco ,and yes it could be that its the brightness changing issue than a flicker. i mean its not a strobe lite and i kind of leaning toward replaceing the regulator any way. if i go with a new electronic regulator will it also need the condencer . thanks BILL
If it does it with the doors open,first check as jensenracing77 said.The door switches may be worn,loose,or have a bad ground,vibration with the engine running could be rattling them a bit.Better and cheaper than regulater,etc. ---bil
The condenser at the reg can be left there - it just plugs in.
It will also keep that original look.
The flicker happens as the internal mechanical points open and close.
Get a solid state unit (light as a feather compared to the mechanical one) and put the old unit in the trunk as a spare.
I think I heard some folks getting ss units at Napa.
Not sure - it might take some shopping around. Take in your mech one in and compare the weights. The ss unit will be very light.
Mine came from an independent starter / alt rebuilding shop - no name on the unit at all.
sorry to dig up an old thread, but did anyone over find a place to get one? When my headlights are on, they flicker as well as the dash lights. The lights don't turn off, just the brightness is constantly changing. Thinking it's probably a voltage regulator. Hoping it is anyway.
I bought a new one, and after installing it I've got 16.4v going to the battery with and without a load. No fluctuation with engine speed. This has to be too much, right?
I opened it to look. I gave them the Carquest number and this is what it crossed to. First picture is of the new vs old. Old on the left with the radio static reducer thing. Second picture is of it opened up. Now I went to a car thing last night in CT, I ended up putting the old VR on the car. I sanded down the connectors and such to clean them. Didn't notice much fluctuation at all. They did get a little brighter (not much) when I tromped on the car hard on the on ramp to the highway, but other than that, it seemed fine. So the new one, putting out over 16 volts, thats junk right?
Alrighty. Thank you. I thought it was high, but I just wanted to double check. I'll be exchanging it. Thanks for the information.
I had pulsating light issues, I bought this same votage regulator and after I installed it my lights or all lights seemed to get very bright when I reved the engine, ( not all the time- I started it again and it seemed fine). Well I drove it to a car show and seemed fine on the way home ( the lights). 2 days later I went to start the car and the battery was dead. So now I'm not sure if I overcharged the battery, this sounds like the same overcharging problem you had. I'm trickle charging my battery, I hope I can bring it back to life. I think I'm going to change over to internal alternator regulator, Just hope it's not a big deal to change over. Please let me know if it is tricky to change to internal regulator system. Thanks Barb.
Blake Willoughby
February 5th, 2012 09:29 AM
gearheads78
November 28th, 2011 01:46 PM
