Interior Lights
Interior Lights
Ok when I was under the dash I noticed there were no courtesy lights? so before I dig out my SM later tomorrow. How many lights are there in the interior and what lights up in the dash/console?
Magna
Magna
OK...off the top of my head the instrument pods should all light up. One above the headlight switch. One above the wiper switch. Two over the heater control. Then there should be two (or is that three?) that are bulbs clipped into holes in the bottom of the metal dash that shine toward the floorboard.
Then the console will have the shifter selector lit up and one in the storage compartment.
There should be a dome light in the center of the headliner and some cars have lights in the rear sail panel.
If I missed any other members will have to chime in
John
John
I am not familiar with the features at every Olds trim level, but I believe that at the lower levels, the under-dash lights were optional, and part of the "courtesy" or "lighting" package.
Most were in the "mirrors and lamps" package, optional on hardtops but standard in verts (most likely since they could not get a regular dome light).
Standard lighting would be a dome light and the gauge lights (and one in the radio if there was one).
The L&M pkg added headlight switch light, floodlights for the wiper, cruise, and A/C controls, lights for ash tray, glove box, underhood, trunk, and front footwells. Also a maplight on the dash and in the mirror, along with vanity mirror on right front.
Did hardtops get rear quarter courtesy lights? I thought so but not sure.
It looks like my car has part of that package anyhow , not sure about the ashtray but have the one for the mirror , and under or behind every switch and dial . I will have to do some investigation on the matter. I also have the footlights , under the hood ( don't work ) , in the glove ( don't work ) .
Under hood lamp, 2 lamps over wiper switch/cruise switch/conv.top switch, 2 instead of one light over AC controls, one light to the right of radio, glove box light, mirror map light, passenger side visor mirror, driver & passenger side footwell lights, trunk light, ash tray light, very small light over headlight switch. Console has the shifter indicator light, console storage light and rear footwell.
If you had a supreme coupe, 2 more in C pillar.
My '71 has all the instrument lighting mentioned, the dome light, a light in the rear bottom of the console (also shines inside console box when lid is opened), trunk light and underhood light but also NO lights under the dash by the kickpanels.
Well was crawling around the car today and my car has the basic lighting package. I'm missing the trunk light be see the connector. Have to see if a hood light connector is up front somewhere. So have gauges/one over a/c controls/dome/console rear and console GB light missing and shift indicator. Now I discovered today that my indicator doesnt work but if I open my console it light up the indicator? If I turn on the headlight switch it turns off? WTF?
oldstuff
September 13th, 2011 08:03 AM
