Installing a WonderBar Radio in a 1968 Cutlass
Old Jun 11, 2017 | 12:30 PM
wyteon's Avatar
I recently obtained a factory Wonderbar AM/FM radio to install in my 1968 Cutlass. The radio does work in both modes. The installation is giving me fits. Has anybody had experience with this installation and was successful. I have researched both the 68 and 69 assembly manuals and they do not reference the Wonderbar Radio. Also, there is no indication on the radio chassis as to a ground attachment as with the radios referenced in the assembly manuals. Any help with this would be much appreciated.
Old Jun 11, 2017 | 12:47 PM
It should ground the same way as any other radio, chassis and the antenna shield wire. The speaker/s (-) also probably grounds to the car chassis.
Old Jun 11, 2017 | 01:21 PM
That might be because the Wonderbar was never factory installed in the A-body cars, only in the full size cars.
Old Jun 11, 2017 | 05:32 PM
wyteon's Avatar
Thanks Joe. You are correct. It was installed in B and C bodies and not A according to the assembly manual for the full size vehicles.
Old Jun 11, 2017 | 05:44 PM
rcorrigan5's Avatar
Randy C.
The heat sink (all those fins attached to the side of the radio) are on the passenger side for radios installed in B/C cars. The heat sink is on the driver side for A-body cars.
Randy C.
Old Dec 17, 2018 | 06:49 PM
servexcell's Avatar
i am looking for one for Abody
Old Dec 17, 2018 | 09:57 PM
72455442RA's Avatar
https://classicoldsmobile.com/forums...bar-radio.html
its a 68 also .......... 240 shipped
Scott
Old Dec 18, 2018 | 05:05 AM
Olds never installed a Woderbar in the A-body cars. It is possible to retrofit one from a full size, but they were not factory.
Old Dec 18, 2018 | 06:30 PM
Yellowstatue's Avatar
To install a Wonderbar in a Cutlass, you must cut or bend the brace between the radio and the glove box.
wyteon
May 25, 2016 12:08 PM
wabasto
May 23, 2016 12:18 PM
borrone821
Mar 30, 2014 01:23 PM
68RocketAction
Dec 29, 2013 09:02 AM
1968Cutlassfallbrook
Jun 19, 2011 07:32 AM
