Ignition Wires - repo vs replacement
Old Aug 22, 2013 | 03:41 PM
stevengerard's Avatar
Three years ago I figured I would try the reproduction date coded ignition wires. I read a few places that although they look good they are not very well made. Turns out I have a ton of spark scatter. I guess I could always keep these repos in my trunk for shows (if that would ever matter as I have never gone to that type of judged show) and put better quality black wires on that work. Is this a typical problem as they are made cheaply, is three years a normal life-span for them?
Any suggestions? Should I get a new set of repos or just go with some other brand. From the searches I found here it looks like Taylor 7mm was decent.
Old Aug 22, 2013 | 03:47 PM
I like the Taylor wire sets.
Old Aug 22, 2013 | 07:48 PM
redoldsman's Avatar
Proud Viet Nam Veteran
DO NOT get repro wires from Fusick. I bought a set for the 54 and a mechanic worked for several days trying to get the car to run. This was after an engine fire so it was not a matter of just replacing the ignition wires. They finally put on a set of wires they had laying around and the car started right up. It now has Accel wires on it and runs fine. I have never used Taylor wires but if oldcutlass says they work, I would trust them.
Old Aug 22, 2013 | 08:44 PM
rocketraider's Avatar
Oldsdruid
I bought several sets of NOS Delco-Packard plug wires still in their boxes fairly cheap on ebay several years ago. Yeah, you have to know your way around the parts book to make sure they're the right ones, but they will fit and perform right. You can often get correct date codes too, but big deal- they're always 1-Q-XX or 3-Q-XX anyway.
I've had decent luck with Accel. I've never used Taylors. Let's just say I'm not a fan of loud colored plug wires.
Old Aug 22, 2013 | 08:49 PM
Thanks, I'll take a look at feebay and see what's there. I know I got the repo wires from one of those places most likeley fusick or partsplace. I read they weren't that good but thought "how bad can a spark plug wire be" well, I got my answer.
Old Aug 22, 2013 | 09:01 PM
I guess your referring to the Accel's yeller. Taylors I use are black.
Old Aug 22, 2013 | 09:08 PM
nsnarsk65cutlass's Avatar
Ya the Accells work fine Mallory is another,To me they are only ignition wires.
Old Aug 22, 2013 | 09:54 PM
yeah, I just found some black taylors, maybe I'll give them a try. I kind of felt wires are wires as well. But I think this is the third set in about 4 years. Might as well get a decent set that will last.
Old Aug 23, 2013 | 01:24 AM
rustyroger's Avatar
'87 Delta 88 Royale
OEM standard wires will be fine unless you have modified your engine for more power.
Roger.
Old Aug 23, 2013 | 03:06 AM
Oldsdruid
Actually I was thinking of those fluorescent pink, green and orange wires Taylor offers. I could deal with the yaller Accels and had them on a lot of cars thru the years.
Hadn't thought about Mallory- they're good, just no one around here carried them.
Old Aug 23, 2013 | 08:00 AM
redoldsman's Avatar
My Accels are black. It is really not a big deal to me but since they had to be replaced anyway, I thought I might as well use the repro wires. Bad decision. Having Delco on the wires only matters if you are having your car judged at the OCA Nationals or something like that. That is not my cup of tea so I will be running the Accels for a long time. If I found a set of NOS wires at a decent price, I would grab them. There is a big difference in NOS and repro. I am finding more and more repro stuff is junk. I just went through that with and ignition switch from Fusick. It worked about 5-6 times and then quit. It was never even mounted in the dash. It was like $80.00. I bought an NOS one for $85.00 which is still expensive. Then I found another NOS one on ebay and bought it for $31.00.
Old Sep 1, 2013 | 11:20 PM
monaco's Avatar
Hi redoldsman,
can you remember the Part. No of the ACCELs Plug Wire set?
I've to order a set for my 1954 (324 Rocket) but Im not 100% sure which one.
Thanks,
Monaco
Old Sep 2, 2013 | 03:48 AM
Gunmars's Avatar
I bought Scott Performance Wire for my olds and proceeded to switch all my cars over. Tell him the motor you have and you get correct length, hand crafted set of beefy wires.
Old Sep 2, 2013 | 08:12 AM
redoldsman's Avatar
Originally Posted by monaco
Hi redoldsman,
Thanks,
Monaco
Monaco:
I don't know the number. The mechanic put them on there when they were repairing the engine fire damage. I do know he had to cut them to length. Sounds like the Scott's were that Gunmars used may be the best deal. I have never heard of them but nothing beats a good recommendation.
Old Sep 2, 2013 | 11:56 AM
monaco's Avatar
Thanks, made a search on the net. Seems that Standart Motor Products No. 7815 will fit the 324cui engine. I'll give them a try, they are not expensive.
Old Sep 2, 2013 | 06:23 PM
redoldsman's Avatar
It has been a good many years since I bought any Standard stuff but I remember it being a good product at a reasonable price. You should be fine with those. I would not hesitate to buy them.
Old Sep 2, 2013 | 06:51 PM
OLD SKL 69's Avatar
GM Enthusiast
I had the same issue with a set of repo wires from Lectric Limited. They lasted about 4 years and then developed the same issue of spark scatter.
I used to work in a NAPA store and really liked the quality of Belden wires. They look stock and were made very well. I managed to locate a couple sets and that's what I'm using now.
Old Sep 2, 2013 | 11:48 PM
monaco's Avatar
well, Lectric Limited showing only spark plug wires from 1961 up on there webside anyway.
Heard that the Belden wires are good stuff, but the NAPA online catalog are not showing spark plug sets for 1954 Olds. I have to find Part No.'s, because a friend of mine is on vacation in the staates and will pick up some stuff for me and bring it to my place.
Thanks again, redoldsman!!!
Olds luvr
Dec 17, 2016 02:26 PM
Hawghead
Jul 18, 2014 12:51 PM
johnnyhawthorn
Feb 12, 2014 11:47 AM
hobs
Jun 5, 2011 11:23 AM
johnspd22
Feb 20, 2010 03:42 PM
