Ignition Problem - Burning up coils
Old May 27, 2011 | 03:11 PM
red&blue442's Avatar
I've got a 69 442 with almost everything stock. For some reason I've had 4 coils go bad in the last couple months. I figured out that the resistive wire went bad, so I installed an Accell ballast resistor with 1.35 ohms. At first the resistor smoked a little, but still worked. After a week or so the car wouldn't start and I checked everything out and the coil was bad again, and also the resistor became a short, no resistance anymore. Not sure what the problem causing this could be, and any help or ideas would be appreciated.
Old May 27, 2011 | 05:22 PM
That's just weird.
Are you buying one brand / model of coil over and over, or did you mix it up a bit?
Any chance you've got an intermittent short to ground in your distributor?
Have you checked your dwell angle recently?
Way too much dwell would be an obvious answer.
Old May 28, 2011 | 06:47 AM
rustyroger's Avatar
'87 Delta 88 Royale
Have checked the condensor?, as well as burning up points it can hurt the coil if it has gone bad. Normally you would have starting and running issues too, but worth a look IMO.
Old May 29, 2011 | 11:48 PM
I have tried different types of coils, all were oe replacements that need the external resistor. I don't think I have a short in the distributor, but I'm gonna double check all my grounds. And I will check my dwell I didn't think of that. I have replaced both the condenser on top of the coil and the one inside the distributor.
Thanks!
442_Mustang
Suspension & Handling
Apr 14, 2010 02:21 PM
Wilson05
May 12, 2009 10:04 AM
veltboy618
Apr 1, 2009 06:57 AM
smcurro
Feb 2, 2009 11:27 AM
gumbyssfakee
Jan 6, 2009 02:11 PM
