Ignition help
Old May 4, 2018 | 01:47 PM
rocket4421's Avatar
Ignition help
guys I have a problem that may take someone else’s knowledge because mine is limited. Here my problem I turn the key to the On position no lights I turn the key to the start position like I’m trying to start it and the lights come on I have a voltage gauge that doesn’t show any voltage until I’m actually turning the key toStart the car car cranks like it’s going to start but is soon as I let off of the key I lose all power anybody have any ideas I would really appreciate it thanks
Old May 4, 2018 | 02:38 PM
I moved your thread to the electrical section. First off what year and model car are we talking about. What distributor are you running? On your initial description your missing the run circuit, no voltage to the coil + terminal when the key is in the run position. Have you been working on any projects that may have caused this issue?
Old May 5, 2018 | 05:13 AM
rocket4421's Avatar
1969 442 i have a msd distributor i noticed a month ago while driving what seemed like a total loss of power (for a second) then power was back yesterday went to the garage turned on the ket should of had gen and oil light come on but there was nothing then i would turn key to start car act like it wants to start till i release the key all dead again thanks for the help guys
Old May 5, 2018 | 05:37 AM
I'm afraid we need more info. A 1969 442 doesn't have a voltage gauge, so obviously that has been added. What else has been added to the car? How were these aftermarket gauges wired up? What "lights" are you talking about not coming on (the idiot lights are only supposed to come on in the START position as a "lamp test" function).
Old May 8, 2018 | 02:50 PM
rocket4421's Avatar
ok so what I’ve found out. And for the record I’m not real up on this stuff just so you guys know but. With my key in the run position I am intermittently getting 12v to the run side of the coil when I engage the start she wants to start and will occasionally just not all the time I have tested with the key in the run position and I will get 12 v to the negative battery post but not all the time it’s like a crap shoot. Now she is almost 50 years old. Any off the cuff ideas or should I just trace the run circuit all the way out. Sorry for not posting sooner just been busy thanks guys.
Old May 8, 2018 | 02:58 PM
Where is your MSD distributor getting its power?
Old May 8, 2018 | 03:04 PM
rocket4421's Avatar
well I’ve bought what to me looks like the stock type replacement I would have to ask my mechanic buddy who installed it
Old May 8, 2018 | 03:06 PM
rocket4421's Avatar
would a picture help?
Old May 8, 2018 | 03:12 PM
Yes... A stock style replacement would have points. I don't think MSD makes a points style distributor.
Old May 8, 2018 | 03:26 PM
rocket4421's Avatar
This is what we are dealing with now the car has ran for a year and a half with this installed
Old May 8, 2018 | 03:38 PM
What is the part number of the distributor?
Old May 8, 2018 | 03:52 PM
rocket4421's Avatar
8529 that is the part number on the box this is a 400 engine 4 spd. And thank you for the help.
Old May 8, 2018 | 03:54 PM
Ok, you can remove and stow the wires on the coil+ terminal. Then run a temporary jumper 12/14ga wire from your battery+ to the coil+ terminal and eliminate all the cars wiring. You still need to crank the engine with the key. In order to shut it off you need to remove the temporary jumper. Also if your car has a tach disconnect that wire off the coil- terminal.
rocket4421's Avatar
By the way I’ve posted a few picks in the gallery the car we are talking about is the maroon and gold one.
Old May 8, 2018 | 04:25 PM
rocket4421's Avatar
Thank you sir for the info and your time. Olds guy for life I am truly grateful.
Old May 8, 2018 | 06:41 PM
Did it start right up?
Old May 12, 2018 | 06:30 AM
rocket4421's Avatar
Ok so here’s what I got I did take a wire to the battery and the car fired right up. So I disconnected wiring from coil and metered it. With some help to read the meter I found that with the key in the run position I would and could get 12v on the coil wire but I would have to jiggle /jostle the key around a bit so I’m kinda thinking it’s the key cylinder any thoughts.
Old May 12, 2018 | 06:42 AM
Nice car by the way. It may be the ignition switch. Drip some 3 in one oil on the key and insert it into the cylinder and repeat a few times. See if that cures it.
Old May 12, 2018 | 06:44 AM
rocket4421's Avatar
Thanks I will try it. And thanks for your help I really appreciate it.
Old May 12, 2018 | 06:55 AM
Your welcome, let us know what the end result is.
rocket4421's Avatar
Ok that did nothing for me the key works in the start position and in the accessory position so I think it is the key or is there a electrical switch on the column I should replace first ? That being said does anyone have a tutorial of how the ignition switch is removed without damaging the column and where can I buy one that matches the original. Thanks
Old May 12, 2018 | 07:39 AM
Sorry confused myself, yours is a column mounted switch. Someone else may need to walk you through an adjustment procedure if its possible. The switch is mounted to the column and there is a rod that runs from the tumbler to the switch.
Old May 12, 2018 | 08:36 AM
rocket4421's Avatar
Ignition key
Does anyone know where you can buy a brand new ignition cam for a 1969 442. Or get my original rebuilt. Thanks
Old May 12, 2018 | 08:39 AM
lemoldsnut's Avatar
Do you mean the tumbler assembly? If so you can buy it new on rockauto.com or any of the parts restoration sellers. A good lock smith can do things too. Often it is a worn out key that is the problem.
Hope this is some help
Larry
Old May 12, 2018 | 08:41 AM
rocket4421's Avatar
I’ve seen the one on restoration sites but they don’t look like the original thanks though
Old May 12, 2018 | 08:42 AM
rocket4421's Avatar
CRUZN 66's Avatar
Olds Fever
What is the actual ignition problem causing you to believe you need a new cylinder???
Old May 12, 2018 | 08:44 AM
CRUZN 66's Avatar
Olds Fever
Ignore my previous post, just saw your other post about your problem...
Old May 12, 2018 | 08:46 AM
rocket4421's Avatar
No voltage to the coil in the run position unless I jiggle the key tumbler if I move it back and forth in the run position it will get 12v. To the coil but the slightest movement back to zero
Old May 12, 2018 | 08:56 AM
lemoldsnut's Avatar
If I read your post correctly about the ignition issue, it is not the ( tumbler key) it is the ignition switch you need to replace. This is on the column below where it meets the dash. It has two screws that hold it to the column and a rod goes from the tumbler set up to it and makes if move to position the car from off to run and start as well as from off to accessory. This is where a service manual would be helpful for you. A test light is a great tool for this on these cars.
If it is the ignition switch. So not the key but the switch on the column lower on the column. These are available at the previously mentioned parts places as well as your local parts store. A tilt column and a non-tilt column uses different switches.
I just did one on a 72 and it was $12 at Orielly auto parts.
Old May 12, 2018 | 09:00 AM
  #31
This place sells parts, however it may be an adjustment or the connecting assy that is the issue.
http://www.steeringcolumnservices.co...s-non-tilt.php
Old May 12, 2018 | 09:03 AM
  #32
rocket4421's Avatar
thanks so much I will try that first for sure.
Old May 12, 2018 | 09:07 AM
  #33
lemoldsnut's Avatar
That switch is also adjustable about a 1/4 inch or so. It is held on with two screws that are very short. It is on the top of the column on the left side as you sit in the car. has two plug ins that make one. very common to have issues and if you pull it loose. you can move it with a small screw driver and check it with a test light.
Hope this helps
Larry
Old May 12, 2018 | 10:02 AM
  #34
This is another example of why starting two separate threads on the same topic is a bad idea.
Old May 12, 2018 | 12:02 PM
  #35
I went ahead and merged them together.
Old May 12, 2018 | 07:09 PM
  #36
rocket4421's Avatar
Worked I’m back on the road drove her around for tree hours tonight. Guys thanks for the help.
kandelino
Dec 20, 2010 12:54 PM
bbg2d
Apr 30, 2010 02:27 AM
mryoung4815
Apr 21, 2010 08:20 AM
2blu442
Jan 3, 2010 07:34 PM
1FSTLS1
Dec 20, 2008 05:45 AM
