ignition coil
Old Feb 26, 2009 | 01:26 PM
liquidpower's Avatar
ignition coil
Decided to replace my condenser and ignition coil so I pick up the msd blaster 2. Once after looking at the diagram I see that there is only one wire going to the + part of the coil but on my car there are 2. If still using the point distributor msd says you need a .8 resister on the + wire but I have no clue witch one to put it on should I put it on both. After some reading I find out that some cars have wires also have a second wire from the starter so that on startup it gets a full 12 V
Old Feb 26, 2009 | 02:05 PM
Yoooooooooo Hoooooooooooo Rob where are you?
Hang in there my friend.
We've got some guys with lots of lectic smarts.
I just don't happen to be one of them.
Old Feb 26, 2009 | 02:13 PM
citcapp's Avatar
What year is your Olds? this will help determine the right information
Old Feb 26, 2009 | 03:21 PM
its 1970 98 with the 455 4b
Old Feb 26, 2009 | 03:32 PM
Oldsguy's Avatar
Past Administrator
liquidpower, as you can see we have some active moderators here and friendly members as well. Welcome to our site and you will soon be posting without any restrictions (only one more for you).
Old Feb 26, 2009 | 04:55 PM
citcapp's Avatar
liquidpower,
One of the wires comes from the starter to the coil to provide higher voltage when starting. The other wire is a calibrated resistance wire supplying power from the ignition switch to the coil when the car is running. This wire should be very flexable and identifiable from the wire from the starter and is usually black in color. Hook the new coil up just like the old coil is hooked up and you will be fine. Good luck
Old Feb 26, 2009 | 06:31 PM
so don't even worry about putting on the resistor on the black wire msd said i should but ill give it a shot and if it runs crappy then ill just put the resistor on the black one
thanks a million guys
love this site
Old Feb 27, 2009 | 06:53 AM
citcapp's Avatar
What I am saying is the resistance wire should already be there. If it isn't then you need to add the resistor, But from you discription it sounds like it is already there
Old Feb 27, 2009 | 04:07 PM
thanks
appreciate it just wonder what the consequences cloud be if i didn't have one all ready and didn't put one on maybe the points arcing. or the coil melting and my car bursting in the flames
Old Feb 27, 2009 | 04:37 PM
jensenracing77's Avatar
citcapp is right. if it is still the factory wiring then you wont need the resistor. the way to check this is with a volt meter. turn the key switch to run and see what the voltage is. if it is 12 volts then you will need the resistor. if it is (i can't remember for sure) i think 6 or 7 volts then you will not need it.
Old Feb 28, 2009 | 02:36 AM
88 coupe's Avatar
Junior Member
Originally Posted by liquidpower
Decided to replace my condenser and ignition coil so I pick up the msd blaster ........
Unless it fails prematurely, the condenser is normally replaced, along with the points. Most coils will last the life of the car.
In your application, the MSD coil is no different than the OEM unit you are replacing. Some might think it is prettier, but that's it.
Just put the wires on the same terminals.
Norm
Old Feb 28, 2009 | 04:52 AM
MN71W30's Avatar
I can help
Let me road test it when your done.
matt68
Sep 11, 2009 05:19 PM
NikkiLee
Mar 22, 2009 04:27 PM
cisco88
Jan 27, 2009 09:28 AM
1FSTLS1
Dec 20, 2008 05:45 AM
68conv455
Feb 20, 2008 02:36 AM
