Horn problem
Old Jun 26, 2018 | 05:32 PM
Rjharp's Avatar
Horn problem
Hi guys. I think the answer is relay but I am not real good with this stuff so I ask. When I push the horn button the relay clicks. If I put a jumper wire from the positive battery post to the connector with the black wire the horns beep. Bad relay?
Old Jun 26, 2018 | 07:18 PM
Yellowstatue's Avatar
There is a lot of corrosion on those contacts. Clean them well with a wire brush or sand paper and try again.
Old Jun 27, 2018 | 02:48 AM
Rjharp's Avatar
Will do.
Old Jun 27, 2018 | 10:21 AM
Rjharp's Avatar
A little sandpaper did the trick. Thanks.
tdmvlm
Dec 30, 2018 07:49 AM
Dylan Taylor
Sep 8, 2018 03:43 PM
Rustbucket2
Sep 3, 2018 02:17 PM
budg
Aug 31, 2017 03:29 PM
cbogartjr
Aug 6, 2016 04:48 PM
