horn issues - where is the switch contact made at the pad?
Old May 10, 2022 | 07:40 AM
SteveB's Avatar
Question horn issues - where is the switch contact made at the pad?
Hi,
1971 Cutlass (base coupe) with the standard "delta" style wheel.
Recently got the wheel restored (SteeringWheelBob, highly recommended, but not inexpensive).
Can't imagine I didn't test the horn when I put the wheel back in (several months ago) but now I have no horn.
Diagnostics: horns, relay, and wiring up the column are ALL GOOD. If I jump a wire across the floating plate (under the pad) to the column post, I get horn; the spring/plunger providing current to the plate is intact and making good contact (cleaned).
The question is, when the pad is depressed, WHERE is the contact point to ground out and complete the circuit? Possibly it was painted over in the restore. Or is there a missing contact clip? I don't recall anything being there.
Again, everything is correct right up to the horn pad. I'm just not getting contact when I move the pad / plate.
Thanks in advance.
Steve
Vfilms
Mar 1, 2016 03:15 PM
Dave Siltman
Sep 18, 2014 03:51 PM
Fletch06
Jul 27, 2014 10:13 AM
pdqbob
Mar 16, 2014 08:24 AM
Dave Siltman
Oct 27, 2013 05:26 AM
