Horn contact
Old Mar 16, 2024 | 09:30 AM
Pug Wrangler's Avatar
Horn contact
I gave up on fixing my horn almost 2 years ago to move on with other issues. I have a 72 Cutlass with an aftermarket sport wheel. It seems like I needed a longer contact pin, is this correct and does anyone have a part number?
Old Mar 16, 2024 | 02:01 PM
4speed455's Avatar
You need Dorman 83230 or equivalent. Same parts used on Corvette so readily available for $7-10. And the horn contact ring. I don’t have a part number for that one but here is one on eBay for $27.50 https://www.ebay.com/itm/12414932375...Bk9SR6rs_ZDJYw
Old Mar 16, 2024 | 02:06 PM
I didn't know I had to change the ring also, thank you.
Old Mar 16, 2024 | 02:10 PM
4speed455's Avatar
Your welcome. Also on the Dorman kit, the spring goes in the hole first, then the pin with the wider spot first, finally the plastic collar slides over the pin and locks it into place.
Old Mar 16, 2024 | 02:40 PM
Which "ring"? The cancel cam?
Old Mar 16, 2024 | 03:59 PM
It says horn contact
Old Mar 16, 2024 | 04:08 PM
Again, are you talking about the small black ring that holds the HORN CONTACT in the tube on the cancel cam, or the HORN CONTACT ring that is part of the cancel cam itself?
Old Mar 16, 2024 | 04:17 PM
The small ring comes with the contact kit. 4speed says I also need the contact ring also. I don't know if I do or not.
Old Mar 16, 2024 | 04:20 PM
If by contact ring you mean the spring-loaded ring that the horn cap snaps into, you can't mount the horn cap without it.
Old Mar 16, 2024 | 04:24 PM
I have one, he says I need a different one.
Old Mar 16, 2024 | 04:26 PM
They all look exactly like the one in the photo above.
Old Mar 16, 2024 | 04:34 PM
Okay then. Thank you for clearing that up for me Joe
Old Mar 16, 2024 | 11:13 PM
4speed455's Avatar
Sorry I didn’t mean to cause any confusion, I was just showing the correct parts to make your horn work.
Old Mar 17, 2024 | 08:04 AM
No worries, I misunderstood.
Old Mar 23, 2024 | 09:43 AM
Is this right? The wide end of the pin doesn'
t want to fit into the sleeve
Old Mar 23, 2024 | 09:54 AM
Yes that is correct.
Old Mar 23, 2024 | 10:08 AM
thank you Joe
Old Mar 23, 2024 | 12:58 PM
I'm so close! one more question. Do the tabs on the contact ring go above or below the steering wheel? If I put them on top the horn doesn't sound, if I put them below I can't get the cap on.
Old Mar 23, 2024 | 03:18 PM
70Post's Avatar
Horn contact ring goes on AFTER the steering wheel is installed on to the hub. Sometimes there isn't enough "travel" allowed for the horn contact ring "springy" part to contact whatever it contacts to make the horns honk. You could try three small flat washers b/n the horn contact ring tabs (one under each tab) and the steering wheel face.....see if that gets the horn to work.
Old Mar 23, 2024 | 05:00 PM
That might work, thanks!
Old Mar 24, 2024 | 09:00 AM
That did it! I had to grind the washers way down so they didn't make contact with the inner part of the ring, o-rings probably would have worked better.
Thanks for all the help guys!
Huero59
Dec 1, 2023 04:32 AM
sjay1989
Feb 5, 2020 04:16 PM
88hurstolds
Jan 18, 2016 09:18 AM
DennisG.
Apr 15, 2012 11:01 AM
orange442
May 14, 2006 03:06 PM
