Help...electrical nightmare!
Old Aug 19, 2011 | 08:28 AM
Southern_Hospitality's Avatar
Good morning OLDS enthusiasts. I have a bit of an electrical problem. My parking and dash lights went bye-bye while I was driving last night. A mechanic is estimating $98/hr to check it out (I ran for the hills, lol). Can you guys help me do some troubleshooting. Which fuse should I check?
Old Aug 19, 2011 | 09:38 AM
76 Regency's Avatar
If you can't tell which fuse is which because the labels are likely faded off, take a multi-meter (using the continuity setting) and check each fuse without taking them out (just touch the 2 ends of the meter to each of the fuse). At least on my '76, the dash light fuse is a very small one at the very top of the panel..a little tough to get to sometimes. If you don't have a meter, you can do a quick check by using a paperclip and touching both ends of each fuse. When your lights turn back on, you found your fuse.
Keep in mind, a blown fuse means a short of some kind...maybe a wire is loose somewhere and is contacting something it shouldn't be. Unless the wrong fuse is in there (too small), it will likely blow again.
Good luck.
Old Aug 19, 2011 | 09:39 AM
jaunty75's Avatar
They're labeled on the fuse panel, and there aren't very many of them in total. It should take you less than five minutes with a flashlight to give them all a good look and see if any are blown. The dash lights usually have a separate, small 4-amp fuse, and it will be labeled "courtesy lights" or something like that.
Old Aug 19, 2011 | 10:01 AM
"Courtesy" is a big fuse for interior lighting, clock and cig. lighter.
"Inst" is a small fuse for dash lights.
Old Aug 19, 2011 | 10:05 AM
Lady72nRob71's Avatar
That one is labeled INST LPS. That fuse gets its power from the TAIL fuse.
Old Aug 19, 2011 | 05:46 PM
greenslade's Avatar
use a test light both side of fuse should have power,if there is power on 1 side only then the fuse is blown.
80cutlass350rocket
Mar 5, 2014 06:30 PM
oldsonharmont
Jan 24, 2010 07:47 PM
72cuttyvert
Sep 3, 2009 02:17 AM
HARDLUCK88
Apr 22, 2009 10:39 PM
Droopys Garage
Aug 1, 2008 06:01 PM
